Go to Post FIRST doesn't end after high school, for some of us, it is only beginning. - David Kelly [more]
Unread 05-11-2013, 11:19 AM
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
Getting axis camera image on desktop.
Hello. I am working on making our next custom dashboard in processing. I have made network tables work fine with it, now I just need to get the camera image. Does anyone know how I could get the Axis camera image and display it in processing? would I have to do a CGI request? If so, how would I do it? I know the basics of a CGI request but am inexperienced in implementation and usage.
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
Unread 05-11-2013, 04:02 PM
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Getting axis camera image on desktop.
deleted misread OP's post
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 05-11-2013, 07:34 PM
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
lol I guess someone liked the Custom Processing Dashboard idea :P The best option is probably Worley's. It's pretty easy to imbed a processing applet in a web browser.
Unread 05-11-2013, 09:12 PM
Hypnotoad's Avatar
I had the idea of copying the address of the in browser image and using it in processing too. Unfortunately, I found that it is an mjpg and Processing cannot load mjpgs.
HOWEVER!!! I went out hunting and found this. It seems I am not the first to want axis camera images in processing. The library worked flawlessly and the image came up. My elation at seing something work on the first try was unbelievable.
The process to make it work is simple:
install the library.
Open the camera in browser.
Right click on the live image -> copy image URL.
open the example sketch that comes with IPCapture
replace the address in
cam = new IPCapture(this, "http://212.219.113.227/axis-cgi/mjpg/video.cgi", "", "");
with whatever is in your clipboard from the earlier copy you did.
Run it!
My teeth are false.
Unread 05-11-2013, 09:44 PM
ekapalka's Avatar
FRC #3216
Helped with that :P It only works with old versions of Processing (but it's fine in Eclipse and NetBeans, so not worth fixing). An additional tool (in case you're going the browser way) is Processing.Js. It makes it really easy to mesh HTML with Processing.
Unread 05-11-2013, 09:52 PM
Hypnotoad's Avatar
Sorry I don't understand the first part of your post. What do you mean by "helped with that", and "it only works with old versions of processing".
The browser way works with the latest version of processing perfectly well for me, as well as with netbeans. (have not tried it with eclipse)
My teeth are false.
Unread 05-11-2013, 10:08 PM
ekapalka's Avatar
FRC #3216
IPcapture. It doesn't work with new versions of Processing, but it works fine in old versions, Eclipse, and NetBeans. Try it with the latest version of Processing. It shouldn't work.
*edit* actually Stefano updated it a bit since I last worked on it. It works with Processing 2.0 :D Sorry for the confusion!
