Go to Post Based on my experience coaching basketball and robotics, there is no doubt in my mind that if a sports coach receives $x then a robotics coach should, too. - dtengineering [more]
Unread 23-01-2003, 12:25
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
2 mm key stock
For those of you who are worried about losing those tiny little 2mm keys at competition, McMaster Carr (www.mcmaster.com) sells 2 mm key stock.
Neither SPI or MSC carry it.
Andrew, Team 356
Unread 31-01-2003, 09:01
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Thank you
Andrew,
Thanks for posting this time saving info.
Andy B.
Unread 01-02-2003, 09:16
Dr.Bot
Posts: n/a
what package did the 2mm come in, and what did it look like?
No one on my team can remember seeing it.
Unread 01-02-2003, 10:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
It came it a late shipment from FIRST with the green pneumatic tubing and stuff. They were in a clear sandwich bag with a blue and yellow zip-lok zipper.
Unread 02-02-2003, 08:20
Dr.Bot
Posts: n/a
Green Tubing?! green tubing?!!?? - we got red tubing - I guess we're in big trouble now!!
Unread 02-02-2003, 11:48
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
We got white tubing... Seems like we're having some colored bots this year!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 03-02-2003, 21:19
Dick Linn's Avatar
no team (Synergy)
2 mm keystock
Don't sem to recall if we got any, but if I needed it, I think I'd pound down a piece of annealed spring wire into a square shape and file it to fit. The work-hardening would be just about right. I had to file/stone every other piece of keystock I've used from the kit, so what else is new? Don't discount the value of a blacksmith, despite the high-tech.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 03-02-2003, 22:12
Re: 2 mm keystock
If you chuck it in a mill, taking off about 2-3 thousandths in each horizontal dimension will do the trick. If your good on the grinder that's a lot quicker than filing but it's not as flat.
Does anyone know how strong that 2mm keystock is? Seemed pretty soft when I cut it with a pair of bolt cutters.
Unread 03-02-2003, 22:29
Dick Linn's Avatar
no team (Synergy)
Shear strength
Depends on the shear strength and the bearing area, I'd expect.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
key to getting grants Jim Harbison Fundraising 2 09-01-2003 18:17
Here Is The Key To Fundraising Success "that's The Ticket"!!! DaBruteForceGuy Fundraising 23 19-11-2002 22:12
Hex key sizes archiver 2001 3 24-06-2002 01:21
The key to this year's game (long) archiver 2001 6 23-06-2002 23:05
The key to this years problem ..... archiver 2001 5 23-06-2002 22:34
