Go to Post ...your mentors are your friends. If you're not sure of something, they probably know the answer to it, and if they don't, they will point you to someone who does. - Karibou [more]
Unread 02-05-2013, 16:59
YCJeon772's Avatar
YCJeon772 YCJeon772 is offline
Mechanical Leader, CAD designer
AKA: Yuchan Jeon
FRC #0772 (SabreBytes)
YCJeon772 is an unknown quantity at this point
1114's Red Ribbon?
I cant believe it took a good 10 minutes to find the new thread button...
But anyways, I was just wondering what that red ribbon on 1114's climber was for. I thought that it was used to pull the arm in, but I may be wrong. And if it is used to pull the arm back, how does that work?
Unread 02-05-2013, 17:01
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: 1114's Red Ribbon?
I have no detailed knowledge, but just based on the speed of climbing, I'm guessing the red strap was wrapped around a pulley that was driven by a power takeoff connected to their drivetrain. So they were using the full power of their drivetrain to lift the robot.
Unread 02-05-2013, 17:04
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
http://www.simbotics.org/first/2013
No PTO. Strap is used to retract the arm.
Starke Starke is online now
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
This video gives an in-depth look into their design. Check it out!
http://www.youtube.com/watch?v=CIBaWdIZX7k
matt
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
1114s climber was powered by a gearbox using 2 cims and 2 mini cims i believe
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 02-05-2013, 17:05
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Their arm is extended with springs (or surgical tubing I can't remember exactly how) and then it is pulled back with a ratchet strap (that's probably the "ribbon" you saw) that is driven off of two CIMs and two Mini-CIMs (not their drive train).
Unread 02-05-2013, 17:06
YCJeon772's Avatar
AKA: Yuchan Jeon
Thanks for those links, they helped a lot.
So it is used to retract the arm. That's cool.
Unread 02-05-2013, 17:09
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Constant force springs extend the climber, winch powered by 2 cims and 2 minicims retract the climber via the red straps.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 11-05-2013, 23:17
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
I have confirmed they use constant force springs to extend it. I just dont understand how, none the less. Well this link will really help there are some great close ups if you were wondering. https://www.dropbox.com/sh/3fxabc28nvvkcr8/A2tQie9tgK
Unread 12-05-2013, 16:50
Chris is me's Avatar
AKA: Pinecone
When a mechanism is run with a winch and pulley + some springs, the "pull" motion is simple - winch winds rope in, mechanism comes with it. To extend, you just run the pulley in reverse. The springs take up the slack in the rope and extend the mechanism.
Unread 12-05-2013, 17:38
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
does the shaft at the rear of there robot serve as part of a function or is it a structural component?
2016: FRC 865 Mentor
Unread 12-05-2013, 17:54
Gregor's Avatar
Outer attachment point for their hanger. Slide it out, hanger comes out.
<Since 2011
Unread 12-05-2013, 17:56
mman1506's Avatar
no team (WARP7)
That's quite elegant, do you know what they use to pivot the arm up and down?
Unread 12-05-2013, 18:02
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
I think that could be the bottom connection point for their climber.
Unread 12-05-2013, 18:18
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
It looks to me that it's the shaft the climber is mounted to and pivots on.
