Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Unread 12-05-2013, 19:04
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Real IRI Rules Changes?
Now that 90+ teams have applied to attend IRI it seems like a good time to discuss possible rule changes to this year's game. It would be helpful to hear from Chris and company what changes might take place so teams could plan/modify their robots if needed...especially if there are any significant changes in climbing values, etc...
"A genius is just a talented person who does his homework" T. Edison
Unread 12-05-2013, 19:15
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: Real IRI Rules Changes?
Increase the value of pyramid goal disks to 10 points each? It wouldn't change the value of most climbers that much but it would be nice to see those goals used a little bit more by objects other than paper airplanes.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 12-05-2013, 19:19
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Since I figure no one at IRI will use the 1 point goal. Just turn it into another column of feeding slots.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
AGPapa's Avatar
AGPapa AGPapa is offline
AKA: Antonio Papa
FRC #5895
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
It would be great if they brought the blizzard back. Let's put up higher nets and watch Ultimate Ascent the way it was meant to be played.
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
Unread 12-05-2013, 19:22
AKA: Cam Pizzo
How many disks will there be for the blizzard in most matches though? It would be really interesting if they let HP's throw them the entire match. It would probably give ground loaders a HUGE advantage but it would make things real interesting!
It also might help fix the "blizzard" since teams could spread the throwing out over the course of 2 minutes as opposed to 30 disks in 30 seconds.
Unread 12-05-2013, 19:30
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
That and if someone's climbing is effected by contact from a robot on the other alliance (or a robot from the other alliance shoving a robot from the alliance of the climbing robot) the point value of all the colored discs in the robot at the time of impact should be given to the alliance of the climber, along with a 30 point climb.
That way shoving a climber+dumper off the pyramid is actually a net loss, rather than a wash on points.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 12-05-2013, 19:32
AGPapa's Avatar
AKA: Antonio Papa
FRC #5895
I don't think that the rule change should be that excessive. I like the idea of the blizzard even if there won't be that many left over discs. The rule change shouldn't drastically change the way the game is played.
Last year's rule change was perfect. It incorporated an aspect of Rebound Rumble that wasn't usually there until eliminations. This year’s rule change should be similar. Every team designed their robot thinking that Human Players could through discs in the last 30 seconds. They should get the opportunity to play the game that their robot was designed for.
Unread 12-05-2013, 19:45
Head Mentor
+1
Also considering the damaged sustain by fallen climbers, maybe revert back to the 10 minute time out for elims?
Unread 12-05-2013, 19:55
Woolly's Avatar
Programming Mentor
Originally Posted by Mark Sheridan View Post
+1
Maybe a rule that reads
"If an ALLIANCE needs to take a TIMEOUT due to their ROBOT being damaged as the direct result of a FOUL or TECHNICAL FOUL by the opposing ALLIANCE, the opposing ALLIANCE will be charged their TIMEOUT which due to the circumstances will last 10 minutes."
Unread 12-05-2013, 19:56
Billfred's Avatar
Billfred Billfred is offline
I'll throw one out: more frisbees. The way frisbees were barely fitting in the center goal Saturday at Championship, I think it would be a legitimate challenge!
Unread 12-05-2013, 20:04
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Or larger goals...
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 12-05-2013, 20:28
Head Mentor
I like that. or at the very least generate a free time out for climbers that fell/damaged due to a foul.
Unread 12-05-2013, 20:30
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
How about the 2pt goals become 3pt goals in the last 15 seconds?
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 12-05-2013, 20:31
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
I like this idea, but then what happens if the other alliance has no timeout left?
Unread 12-05-2013, 20:34
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Pff, too easy. What about making the 1pt goal into a 3pt goal in the last 15 seconds?
