Go to Post Let's all try to get along, it isn't that complicated. - Joe Johnson [more]
Unread 13-05-2013, 13:08
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Re: 6 Wheel Drives Without Dropped Centers
Originally Posted by Travis Hoffman View Post
48 has been running no drop center, 6WD West Coast setups since 2011.
2011: two 4" omnis up front, four 4" performance wheels in rear, roughtop tread. Long wheelbase.
2012: six 8" AM pneumatics, square footprint
2013: six 6" dia. 1" wide aluminum performance wheels, blue nitrile roughtop tread. Very slightly wide-biased footprint.
All three were powered by some variation of the A-M SuperShifter, 2 CIM's per side.
2012 was not surprisingly the least-maneuverable of the three setups, but it still was good enough to get the job done in one of our most productive seasons ever.
The 2013 iteration is very nimble yet able to provide enough punch to apply solid defensive pressure when needed.
Just to clarify for Travis, 48's 2013 drivetrain ran 6-in custom performance wheels with 1-in roughtop tread riveted in place. Due to our relatively square frame, this put our wheel base at 24" between centers (front to back) and about 26.5"-27" between the center tread contacts side to side. It was an all-around quick cycle runner with no problems doing zero-radius turns in either low or high gears.
Our 2012 robot's wheelbase was only an inch wider than it was long, so with the much larger contact patches of the pneumatic tires, it definitely did not turn as well as this year's bot (as mentioned above).
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
