Go to Post I admit that it isn't practical...but it sure is fun. - Crebb [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 14-05-2013, 17:22
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: An Idea for Next Year using WATER!!
Originally Posted by evanperryg View Post
...How exactly does this use water? If they are water balloons, they already used balls filled with water in the 90's (pretty sure it was 1993)
It mentions that the arms are hydraulic.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 15-05-2013, 00:16
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Did you guys design and laser cut those arms yourselves?
Unread 15-05-2013, 01:35
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Neat!
Interesting that you've posted this, I've considered using water as a hydraulic fluid for a FIRST robot, but never had the chance to implement it. I wonder if it would pass inspection?
R08 is the only applicable rule I can find, but it could be debated whether or not dihydrogen monoxide is hazardous.
Originally Posted by R08
ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
Unread 15-05-2013, 01:56
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
In the blue box below 2013's R08, it says "Examples of items that will violate R08 include (but are not limited to)...Hydraulic fluids or hydraulic components".
I read that blue box as constraining the interpretation of R08 to specifically treat all of those things as if they are inherently unsafe (etc.), irrespective of the observed level of safety of a given mechanism at a given time.
Unread 15-05-2013, 08:40
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The potential bad affects of a leak in a hydronic line are really what make it unsafe for FIRST robots. Water and electricity are a bad combination for a robot! Further, a leak would most likely result in "damage" to the field, forcing other matches to play through a puddle/soaked carpet. Regardless of the precautions you might take to prevent leaks, we all know anything can happen with these robots. I've seen hits bend structural frame material before, and arms accidentally get stuck inside another robot causing all sorts of damage to wiring and pneumatic tubing. If the Auto industry can't design a car that doesn't run a risk of leaking brake fluid (granted, they have gotten much better and it's not very common... But it does still happen), I doubt you can design a robot without that same risk!
In a similar way, consider this year's game. With climbing, we anticipated that many teams would want to be able to adjust their center of gravity or weight. A "clever" way to do that would be with a reservoir of sand or bb's or something similar. It seems great, but there's a huge concern for spillage. What happens when the robot takes a hit and bb's go rolling around the field? Field reset would be cleaning them up all weekend! Fortunately, I don't think we saw much of this...
2016: Lake Superior WFFA
Unread 15-05-2013, 18:45
WaterClaw's Avatar
WaterClaw WaterClaw is offline
Comandante
AKA: Andrew A. Matthews
FRC #2512 (Duluth East Daredevils)
Team Role: Tactician
WaterClaw is on a distinguished road
And People were afraid of the water game joke
Insanity is correlative only to the standards of a culture. Cultures are often defined by their technology. Technology only advances by the efforts of those who would be considered insane. So thank your local FIRST team for advancing society.
Unread 16-05-2013, 14:01
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
No we did not this year. These were from pitsco. We are thinking about laser cutting our own designs next year. We are also going to upscale and use pneumatics and plywood over the summer just for fun.
The idea for next year part is a joke !!!
