Go to Post The scent of a smoking Globe motor is familiar to many. - Alan Anderson [more]
Unread 01-02-2003, 12:45
inwoodraider inwoodraider is offline
inwoodraider is an unknown quantity at this point
SMC valve leak?
When we recieved the smc double solonoid valve and assembled them, there was a leak out of the ports when the valves are in the off position. Also, we recieved two gaskets although the SMC website only specifies that there is one gasket. Is this a problem with the gaskets, something we recieved wrong, or our assmebly?
thanks,
team 1155
Unread 02-02-2003, 01:04
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
This has been discussed. But, for reference, only use the rubber pad that has guide holde for the screws and the leak goes away. Well, it did for us.
SMC Double Action Valve. Josh Hambright Pneumatics 2 14-02-2003 10:24
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
Dismantle Solenoid valve? archiver 2001 2 23-06-2002 23:34
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
