Go to Post PS: Please use the default font for postings, it is so much easier to read. - DonRotolo [more]
Unread 23-01-2003, 13:18
Hailfire Hailfire is offline
AKA: Jason
Hailfire has a little shameless behaviour in the past
Send a message via AIM to Hailfire
The numbers on the side adjust the speed. It's not that big of a change but it does get faster and slower. One thing you could do though is create a gearbox to shift gears from low speed to high speed.
Unread 23-01-2003, 19:25
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Re: Re: Re: Programing
Originally posted by Ken L
The whole point of shifting gear ratio in a drive train is to trade off between speed and torque. You have constant power from the motor, and since Power = speed times force, or angular velocity times torque, you get a combinations of speed and force from the motors depending your wheel size and your gear ratio.
By switching to a different ratio, you slow down your robot but you get more pushing force, or you speed up your robot but you have weaker pushing force. Controlling it in software only limit how much power you have from the motor, and thus making the motor weaker when you slow it down, instead of trading off speed for torque.
Few ways I've seen for shifting gear ratio: Drill motor's transmission using a servo or pneumatic cylinder, that's the most simple way for a team to shift gear ratio.
Have two sets of wheels with different ratio, and lower one set at a time depending what ratio you want. You can shift on the fly that way.
Custom gear box like team 45 and 60 last year, or the 67 bot at 2001, where you use pneumatics to move gears outside the drill transmission to from one ratio to another ratio. This is much more complicated, and if your team doesn't already know how to do this, I wouldn't start right with only a few weeks left in the 6 weeks.
Or, you can add more motors to your drive system, and get more mechanical power out of it that way. You have more overall power, and thus more torque and speed at the same time.
Very nice post!
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 23-01-2003, 19:31
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Which numbers on the side? If you're referring to the 1-15 on the black part, that's actually a clutch that will change how much torque the drills will put out before slipping. If you find a real drill with numbers like these (most good ones have them), try setting it to something like 1 and holding the end while you turn it on. It should start clicking and not really provide much force against your hand.
If you're referring to some other numbers, I'm sorry. Could you please explain as I would be quite interested.
--Rob
Unread 27-01-2003, 00:51
Cipher X's Avatar
Cipher X Cipher X is offline
no team (Former SigmaC@t Member)
Cipher X is an unknown quantity at this point
Send a message via AIM to Cipher X
Originally posted by Specialagentjim
Want..to post..but..team kill... if I do....
Sucks being an animator..
$@#$@#$@#$@# Straight! i will be one of the first ones to hurt u jim(jk); LOL
well first lets wait and see if we actually get it to work this eyar before we actually say anything. Once we get its on our robot and working we can brag then!
Cipher X
"Whatever you do will be insignificant, but it is very important that you do it."
-Mahatma Gandhi
Unread 27-01-2003, 18:53
AKA: Jim Martz
Cipher X
Hehe, good point..and if we dont get it to go through, we'll post it online to "Help the other teams in the name of gracious professionalism" and see if anyone else can see what we did wrong.
Unread 01-02-2003, 10:35
AllenH's Avatar
AllenH AllenH is offline
#0111 (WildStang)
AllenH is an unknown quantity at this point
Send a message via AIM to AllenH
Not to bring this up, as i hardly post, but this caught my attention:
Are you serious???? If you are... you might want to confer with the more mechanically inclined members of your team so they can edumacate you better.
However, team 111 has had huge success by limiting the speed control to only 50% when you want to move slower. Only when we want 100 percent by push of the thumb button on the joy stick, we speed off. It's all about the proper gear ratio. There are ratios to maximize speed and power with each motor. You just need to know the magic number
Got Wildstang???
Unread 01-02-2003, 13:22
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Yeah, but the guy was talking about using software control on the drill motors in high gear... major loss of torque there.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 01-02-2003, 13:59
GavinO GavinO is offline
GavinO is an unknown quantity at this point
We used the programmatic shifting last year, and while you can get a bit of control from the lower speed, it doesn't do anything for your pulling power.
Unread 02-02-2003, 22:26
Jim Smith Jim Smith is offline
#0279 (Tech Fusion)
Jim Smith is an unknown quantity at this point
Because the drill motor gear boxes don't like to shift under load, we lock them in low and use a set of spur gears on a slider to shift. Not original, but it works very reliably. This year we're using both the CIM and the drill motors in low. I think we will just push the whole ramp to our goal zone.... Good Luck.
Unread 02-02-2003, 22:59
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
You can get a good Tourqe:Speed ratio through gears yes, but you can change it for higer torque or higher speed through shifting gears.
There are two real ways to shift, 1) Shift the planetary system in the gearbox of the drill motor. 2) Shift actual gears in your gearbox after the motor.
Having X ratio and giving it 50% power will not give you more pushing force, it will only slow your speed. The advantage to limiting power is less draw on the battery, and less chance of overheating your motor. You will NOT gain tourque by supplying less power.
If you look at the power curve for the motors, they are all in accordance to 12 volts being delivered. You can, for the most part, just shift everything down by about 1/2 to see what your speed and torque would be at 50% power. If you change gears however, you'll shift the curve to the left or right.
On the topic at hand..
There are 2 good ways to go about shifting.
1) Servo motor - Turn the servo and it worms the shifter over to a new position. Doesn't take much torque to slide, and the servo doesn't provide much torque.. beatiful combination, rather imple to make with a pretty wide tolerance.
2) Small Pneumatic cylinder
a) above each motor's shifter you can mount a small cylinder that is attached directly to the slider. Pneumatic extends, motor shifts. Program in to not allow motor to be moving to fast when shifting or a nice grinding sound might be heard. And grinding is never a good sound.
b) If the motor's are in line with eachother, you can have a single cylinder mounted above them both. When it extends, it pulls both pins, shifting both motors. You'll have to engineer a bit more with this one so that they both shift to the same gear. If the motors are facing oppisite directions and get the same linear force, they will shift into oppisite gears. (One low, one high). There are ways around this, such as flipping one motor around (which hurts on space) or a reverse pusher. (Reverses force on another bar to change force and shift gears in oppisite directions and same gear.)
c) Within each gearbox, after the motor, have a cylinder actuate a shaft of gears into another position. This works on the same concept as a car's transmission. When cylinder is retracted, gear "a" is being rotated by gear "b". When cylinder is extended, gear "c" is being rotated by gead "d". a and c would be on the same shaft, and gears b and d would be on the same shaft. I don't have any diagrams to show this, but if you hunt around you'll find it.
d) (I saw this in 469's gearbox last year and thought it was a very neat idea). Have the gearboxes in the same orientation as eachother, but the shifting gear (a, c above) be oriented differently. When the cylinder extends, it pushes a and c's shaft to interact c to d. mount a shaft to extend with the cylinder so they both get actuated. If you need more information I can draw up a diagram or contact team 469 about how they did this.
Unread 02-02-2003, 23:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Can someone tell me which position is high speed and which position is low speed?
Unread 03-02-2003, 04:47
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Pushing the gear shift toward the drive shaft connector puts you into low gear.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 05-02-2003, 18:01
With regard to locking the gear on the drill motors: We used a ring of PVC to lock it in, but found that after a while the ring would tend to disintegrate, but the problem would not be noticed till we got a jolt and the motor shifts to nuetral (usually under full power!). So, the locking works, but its a good idea to a) make sure your lock is stable and b) make sure you can get to your motors easily. Just getting the point where wer could bring a screwdriver to bear on those motor mounts required 1/2 hour of work!
Unread 05-02-2003, 21:29
Dick Linn's Avatar
no team (Synergy)
multi-seed trannys
Don't get too carried away with the technology. It all depends on the game rules and the course. Form follows function, and all of that...
Last year. we had a slow, but extremely reliable robot as far as the drivetrain was concerned. No spares, no adjustments, no breakers popping, no hassle. There were enough other things to worry about...
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
gear shifting Stephen Kowski Motors 19 30-03-2003 21:33
Segway-like device being developed by Honda MattK Dean Kamen's Inventions 17 23-11-2002 15:31
RoboStars 'Mini-Arm' Control Device archiver 2000 5 23-06-2002 22:28
Best Ball Collecting device of 2002 D.J. Fluck General Forum 32 07-05-2002 19:15
Like Device sasquatch General Forum 6 31-01-2002 08:51
