Go to Post I think of the FP's as the party motor, they are kinda like mini smoke generators. - coreyjon [more]
Unread 15-05-2013, 18:34
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
Team 2337: 2013 Robot
Here is Team 2337’s robot for Ultimate Ascent, Crossfire.
Extensive robot photos taken by Daniel Ernst, and a couple of team members can be found on the team Google+ page. All of our match videos from inside Michigan are available via the First in Michigan YouTube channel.
Robot CAD will be uploaded to FRC-Designs (post will be edited to reflect link when it is uploaded).
Robot features:
  • Four-CIM, SuperShifter-driven drivetrain in an octagonal shape using the 48/50/60 gearset (slimmed down), direct driven to the center four 4” VexPro VersaWheels, and chained out to the same, inline 4” VexPro VersaWheels. Speed should be around 7.5 and 14.5 fps. This is underpinned by our first sheetmetal chassis at ⅛” inch, with a bottom waterjetted piece and the rest milled.
  • From the ground disc intake, with two top rollers driven by a BAG motor through a 4:1 VexPlanetary through O-rings. The disc would be lifted off the ground slightly by a lexan lip, and then once the roller made contact, the lip would actuate upward with the disc to keep it moving.
  • A large arm driven by a linkage similar to FRC67 from 2007 and FRC148 from 2011. Powered by a MiniCIM, through a custom transmission at 335:1 inside the gearbox and through a wire EDM’d central gear (which had a ratio of 12:100 for a final ratio of 2790).
  • On the arm, a rubber-band disc management system with an upper tray to transfer discs to the two lower trays. The top part and bottom parts are driven separately, each by a AM 550 through a VexPlanetary at a 5:1 and then through timing belts.
  • A double-shooter that can shoot two discs out at once, or one at a time. Each shooter is a single AM 8” pneumatic wheel with about 90 degrees worth of wrap on the disc. The two wheels are direct-driven together by four BaneBot 550s paired together in CIMulators.
  • Two lexan hooks for hanging from level 1, each powered by a pneumatic cylinder and extra rubber banding.
  • Large lexan hood attached to arm for feeder station loading and blocking shots while the robot stays below 60".
  • Attachable blocker that folds down with the arm, and rises up to ~80" (first used at Worlds).
We have open-sourced all of our LabVIEW robot code for Crossfire on our team GitHub page.
Some software highlights:
  • LabVIEW robot project managed with git and hosted by GitHub. During build season, different projects had different branches, and then we completely manually merged code by hand.
  • ”Cheesy Drive”, an RC-style drive system where throttle and steering are on separate joysticks on the same gamepad
  • For intake belt system control, a simple state machine with different states commanded by operator
  • Bang-bang shooter speed-control with a unique bottom gain, tuned for specific speeds
  • Straight autonomous driving tracking the gyro and gyro turns for the 7 and 5 disc autonomous modes
  • Data logging to text file that can be retrieved via the cRIO FTP server. Tracks shooter speed and arm position for checking shots.
  • Last year’s autonomous scripting system with a trapezoidal motion profile algorithm implemented inside (not used in competition)
  • Dashboard-based vision processing (not used in competition)
  • Small usability improvements (from our perspective) NERDViewer.html (from FRC254’s 2012 code release's PoofViewer.html) for driver/operator/coach viewing (not used in competition)
We didn’t look too hard at automated LabVIEW tools for diff and merges - any recommendations would be appreciated. Manual merges were inefficient, not fun, and resulted in refnum naming problems later on. We gave up branching after build season, when a lot of development and tuning happened at competitions, where only one or two programmers were involved, and they would simply work off of the master branch.
2013 Competition Season Performance:
  • Kettering District Quarterfinalists, seventh alliance - second pick, ranked 26th, Engineering Excellence Award
  • Troy District Quarterfinalists, sixth alliance - first pick, ranked 12th, District Chairman’s Award
  • Bedford District Semifinalists, third alliance - second pick, ranked 35th, Gracious Professionalism Award
  • Michigan State Championship Finalists, first alliance - second pick, ranked 52nd, State Chairman’s Award
  • Championship - Galileo Division Semifinalists, third alliance - second pick, ranked 46th
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 15-05-2013, 18:39
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Team 2337: 2013 Robot
One of my favorite robots this year. Good job guys!
All opinions are my own.
Unread 15-05-2013, 18:50
dodar's Avatar
dodar dodar is online now
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Your robot is a circle with a dash in it?
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 15-05-2013, 19:40
kenavt's Avatar
AKA: Colin S
Thanks! Playing your alliance in the Galileo quarterfinals was intense. Two full court shooters between you and 1806.... the thing that will stay with me the longest was 1806 falling off of the pyramid. I still feel really sorry about that.
It should be fixed, thanks. Note to self: do not use Google+ to host embedded photos. I'm not sure why the picture didn't show up, the picture was shared publicly.
Unread 15-05-2013, 21:33
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Loved your bot. It was just fun to watch, though I didn't get to see many matches. I was jealous of your pit, by the way.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 15-05-2013, 22:29
Professional Stat Padder
When discussing my favorite robots at champs, first I would talk about 1503, then about you guys. A double barreled shooter who's also an excellent defender.
Almost makes me wish you were in Archimedes!
Good job to the Enginerds!
(2015-Present)
Unread 06-07-2013, 13:15
kenavt's Avatar
AKA: Colin S
An autonomous readme has been posted to the GitHub page as above. Also, as previously announced by FRC-Designs, robot CAD can be found on the 2013 robot design page.
Thank you so much! With all of the full court shooters in Galileo... it was likely the right place for us to play that fullback role, unfortunately - because Archimedes looked like a blast this year!
It's good that we get to see 2338 quite a bit when our pits are next to each other, at out-of-state events like MARC and Championship. I personally enjoyed playing with your community display, that had the handle to turn the gears displaying the team's partnerships - that was cool! Out of curiosity, what did you like about our pits?
Unread 09-07-2013, 20:00
evanperryg's Avatar
AKA: Evan Grove
Yeah, it's just too bad the chairman's judges didn't like our display :/
Your pit looks pretty good (I'm an AMD guy so I'm partial to the whole red and black thing), looks like it has plenty of storage space and you still have a lot of open floor for the robot. Also like that light over the workbench.
2013
2015
