Go to Post What has happened has happened. Humans were involved, mistakes made. Clarification will come... - Wetzel [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 15-05-2013, 07:50
numerical computation challenge
Find the area between these two curves, accurate to 6 decimal places:
y=10*ln(x+1)/exp(x+1)
x=10*ln(y+1)/exp(y+1)
Use whatever computer tools you want. Show your work.
Unread 15-05-2013, 12:56
Michael Hill's Avatar
Re: numerical computation challenge
I think I solved it....
I got 0.536594(7|8)
My strategy was to use the fact that it was symmetric about x=y.
I took the initial y=... function and rotated it by pi/4 (45 degrees) using the transformation matrix:
[y']   [cos(pi/4)  sin(pi/4)] [y]
[x']   [cos(pi/4) -sin(pi/4)] [x]
That allows me to essentially take the integral above the new y' and simply multiply it by 2. I used MATLAB to get it.
clear
xmin = eval(evalin(symengine, 'numeric::solve(0==y-10*log(y+1)/exp(y+1), y=-0.5..0.5)'));
xmax = eval(evalin(symengine, 'numeric::solve(0==y-10*log(y+1)/exp(y+1), y=0.5..2)'));
error = 1;
stepsize = 3000000;
prevsum = 0;
while (abs(error > 0.000000001))
    stepsize = stepsize + 10000;
    th = pi/4
    x0min = xmin;
    x0max = xmax;
    y0min = xmin;
    y0max = xmax;
    x0 = linspace(x0min,x0max,stepsize);
    y0 = linspace(y0min,y0max,stepsize);
    y = 10*log(x0+1)./exp(x0+1);
    x = 10*log(y0+1)./exp(y0+1);
    xp = x*cos(th) + y0*sin(th);
    yp = y*cos(th) - x0*sin(th);
    xp0 = x/cos(th);
    plot(x0,y,x,y0,xp,yp);
    axis equal
    axis square
    grid on
    sum = 0;
    for i=1:stepsize-1
        sum = sum + (xp0(i+1)-xp0(i))*yp(i);
    end
    sum = sum*2;
    error = sum - prevsum;
    disp('step size');
    disp(stepsize);
    disp('sum');
    disp(sum);
    disp('error');
    disp(error);
end
Unread 15-05-2013, 13:05
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
y'     [cos(pi/2) sin(pi/2)] [y]
x'     [cos(pi/2) -sin(pi/2)] [x]
Rather than going through the trouble of transforming it, I just subtracted the integral of y=x, as that's the symmetry line.
I got 0.536595 for the area -- found the second intercept at .95012, then just took the integral from 0 to .95012 of [10*ln(x)/exp(x)-x] and multiplied by 2.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 15-05-2013, 13:29
Nice job guys. The key was using the y=x symmetry line.
In the attached graph, the red and green lines are the two curves. The cyan line y=x is the axis of symmetry. If you subtract the cyan line from the red curve, you get the black curve.
I used Maxima to find the X-axis intercept of the black curve, and then numerically integrate the black curve from zero to that value and double it.
ID:	14825  Click image for larger version
Unread 15-05-2013, 22:14
Post Re: numerical computation challenge
Of course I go the complicated route. This transcends to my ideas for robots as well. I need to learn to be more elegant. :-P
