Programming Prob-Analog sensors!!
When we look at the Dashboard viewer, we get a value listed under analog 1 from 0-255 however sensor1 is not receiving the value. Yes, all of the sensor1 one lines are uncommented and the serin line does include the sensor1 parameter. (What is the packet_num variable for?) Any ideas for what reason the sensor1 variable is not getting the value for analog 1 . Thanks,
Programmers in Need |
| Communications via the Programming Port | Larry Barello | Technical Discussion | 9 | 10-06-2003 23:33 |
| Robotics Tournament at Sensors Expo & Conference | Kyle Fenton | Off-Season Events | 4 | 04-05-2003 12:15 |
| optical sensors acting strangely | rosebud | Electrical | 10 | 03-02-2003 00:29 |
| pre-built autonomous sensors? | BandChick | Technical Discussion | 4 | 05-01-2003 22:06 |
| Error found in programming for the pump and pressure switch | sjharobotics | Programming | 4 | 06-02-2002 17:46 |
