Go to Post Based on EXTENSIVE analysis of this image, I have concluded that we will have to use wires on our robots. I am certain of it. - theCADguy [more]
  #31   Spotlight this post!
Unread 18-05-2013, 22:42
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Re: 1310 Versatility: 2013 Recap Video
Originally Posted by O'Sancheski View Post
I agree with you that 359 was the best at getting frisbee from the feeder station. But 3824 had the highest shooting percentage and usually had 6 cycles per match. 359 was only getting 4-5. 3824 also had a 5 disc auto.
3824 definitely had the advantage in auto, it looks like 3824 did average more tele-op disc point per match than 359 did, 359 just averaged 1 more disc picked up from the feeder station per match than 3824. 359 was better at getting frisbees, but 3824 was better at scoring.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
  #32   Spotlight this post!
Unread 18-05-2013, 22:54
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Who cares how many frisbees you picked up from the feeder slot? I care about how many you got in the goal.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #33   Spotlight this post!
Unread 19-05-2013, 00:36
registered lurker
AKA: Jake McCann
FRC #3501
If you completely excluded all robots that did anything other than run feeder station cycles (e.g. any robot that ever FCSed, or did ground pick up) then 3824 was the best at getting the most points doing laps from the feeder station to the pyramid. It's hard to compare robots like 1717 and 1310 that did lots of different things.
2011-2015: 1678
2016: 846
  #34   Spotlight this post!
Unread 19-05-2013, 00:37
Gregor's Avatar
I'm referring to comparing 3824 to 359. Both great bots, but why would it matter who can get more disks from the feeder slot? You don't get points for that. You get points for the disks in the goals.
<Since 2011
  #35   Spotlight this post!
Unread 19-05-2013, 00:47
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
I would think they look at both disks scored and disks taken from feeder station.
Sometimes the disks miss the robot while loading.
It would be extremely important to know that although a robot scored 16/16 disks, 10 disks were lost due to feeding error.
By looking at disks scored and disks loaded (and disks missed too), you can not only find the robots teleop points per match and shooting percentage, but also see if a robot is taking an unnecessarily large amount disks that could instead be used by a different alliance partner.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
  #36   Spotlight this post!
Unread 19-05-2013, 02:22
registered lurker
AKA: Jake McCann
FRC #3501
359 and 3824 where very close in both number of cycles per match and number of shots made, in some cases you may want to know if 359 could make one more cycle per match more than 3824 even if they weren't making all of their shots. There's a lot of things you can infer from statistics that statistics won't necessarily tell you. Both of these robots were so close in performance that you can't say that one was absolutely a better cycler than the other, all you can say is that 3824 tends to score slightly more points. In addition, 359 went for the climb much more often than 3824 did, which is also may have caused them to have a lower average disc score. And comparing either of these robots to ones like 1717 and 1310 is much harder to do because we don't know how either of them would perform if they weren't allowed to FCS or do ground pick up, they could be better, or they could be worse than 3824. There were a lot of robots at the top of Curie that were all very good and had very similar performance, it's really hard to say which is the "best" at anything.
2011-2015: 1678
2016: 846
  #37   Spotlight this post!
Unread 20-05-2013, 12:51
BASE's Avatar
BASE BASE is offline
=ARRAYFORMULA() is a thing?
AKA: Rishi Jotsinghani
FRC #3683 (Team Dave)
BASE is on a distinguished road
If you guys are interested, 2056 has uploaded all our matches on Curie. You can find them here:
Qualification Match 13: http://www.youtube.com/watch?v=rfqeoMx0GeI
Qualification Match 21: http://www.youtube.com/watch?v=lqoYS9SxmIo
Qualification Match 35: http://www.youtube.com/watch?v=kCH02oRUVog
Qualification Match 51: http://www.youtube.com/watch?v=KFoDV-6SXWI
Qualification Match 72: http://www.youtube.com/watch?v=YyEC142wuOM
Qualification Match 89: http://www.youtube.com/watch?v=jjV4UJCEBqg
Qualification Match 109: http://www.youtube.com/watch?v=KrDMf2zcEqc
Qualification Match 123: http://www.youtube.com/watch?v=P6TBJN2Km_s
Quarterfinals 2-1: http://www.youtube.com/watch?v=NUU6NaWZnr4
Quarterfinals 2-2: http://www.youtube.com/watch?v=6eH4ghN-4FU
Quarterfinals 2-3: http://www.youtube.com/watch?v=N7rh4xx_ujU
2015-20xx - Drive Coach & Strategy/Scouting Mentor (3683)
2013-2014 - Strategy Mentor (4252 & 1310)
2012 - Team Captain (4252)
