Thread Tools |
Rating:
Display Modes |
Re: 1114 and 2056's shooter wheels
What rpm would you say is the breaking point of the wheels? |
Can't speak for 254, but ours, at 60A durometer, never wore and never had to be replaced (unless they exploded).
What was the advantage of these over the Banebots wheels of the same hardness?
No exaggeration, in the context of this season they pretty much last forever. Our practice bot has shot easily over 10,000 frisbees and the wear is insignificant.
To further prove this point, our banebots wheels would shred. When we switched to the MC wheels we started getting a thin film of plastic on the wheels.
Any comment on approximate RPM it takes to break the suckers as Cory mentioned?
#7
We ran the blue at 10 krpm and poked it with an aluminum shaft a few times. Also took ~ 100 shots at this rpm over the course of the season. Never failed a blue. I'm not comfortable saying it's safe to run 10 krpm as we didn't really give it a fair and realistic lifecycle test. I'm very comfortable saying that with a concentric hub 6k rpm is fine indefinitely. |
#8
As T^2 already mentioned our wheels did not wear at all, instead the plastic form the frisbees actually got melted/caked onto the wheel. You'll probably run out of frisbees before you wear down these wheels. At their off-the-shelf diameter I would not recommend running them at more than ~8,500rpm for more than ~10 seconds as they will literally tear themselves apart as previously mentioned.
#9
I think the reason these wheels fail is largely a function of time. When prototyping we ran a 4" 1:1 off a 550 for a few seconds and the wheel was fine. Every we shot our wheel would expand considerably, and the stress of the repeated expansion coupled with how fast we were running the wheel was what caused it to fail. Like I said the failure is a function of time, not just speed. I believe the urethane wheels are bound to fail at some point when run at FRC speeds. There's no magic rpm that they fail at, it's just a question of how long you want them to last. If you run them at 10,000 rpm or slower they'll probably last a season, anything faster and you're pushing your luck. |
#12
At 2-7/8" we ran them up to 13,000 RPM with no problems, though our normal operating speed was around 10,500 rpm. That works out to almost 10,000 surface feet per minute. The same surface speed for the 4" wheel would be roughly 9000 RPM, though it's going to expand more and give you a higher effective surface speed. I know 233 accidentally ran a 4" one up to 13,000 and it exploded nearly immediately. |
#13
We've been running a pair of these wheels since Wednesday evening of the Championship in our shooter and they're probably the 'best' shooter wheel we've found thus far.
Couple of notes: - They don't 'wear' at least for FRC purposes - The bore on our wheels measured something like .252 - .253" and is a bit rough... Presses can be fun. (2477K36) - Forget trying to cut/damage/mark them using a conventional method. - The wheel will expand a bit as it spins up, we observed something around .125" gain in OD around 5k RPM. Also, add us to the list of those who have had a wheel fail from spinning it too quickly. The Second wheel on our shooter spins somewhere around 11,000rpm at 100% (which is way outside of our normal operating speed) and during testing, we had one of the wheels start to rip itself apart. I have a picture somewhere, if I find it, I'll post it here. |
#14
i would love to try the mcmaster wheels, we used the banebot wheels as the wear was pretty bad, we had to keep replacing them about twice an event.
