Go to Post A robot that can't move isn't a robot. It's just furniture. - John Neun [more]
Unread 01-02-2003, 15:21
LD8 LD8 is offline
#0599 (RoboDox)
Team Role: Student
LD8 is an unknown quantity at this point
Send a message via AIM to LD8 Send a message via Yahoo to LD8
Programming Prob-Analog sensors!!
When we look at the Dashboard viewer, we get a value listed under analog 1 from 0-255 however sensor1 is not receiving the value. Yes, all of the sensor1 one lines are uncommented and the serin line does include the sensor1 parameter. (What is the packet_num variable for?) Any ideas for what reason the sensor1 variable is not getting the value for analog 1 . Thanks,
Programmers in Need
Go Eagles!
Go Lakers!
Unread 01-02-2003, 16:38
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Could you post your code, or at least everything up to and including the SERIN? If you'd rather email it to me, I'd be happy to take a look at it there also. rob-bayer@mn.rr.com
Unread 01-02-2003, 17:34
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Well...
If the sensor in question is one of the light sensors, then your problem is that you are working with a digital sensor and an analog variable...
Unread 03-02-2003, 02:20
If the variables in the Serin are not in the correct order, or there are not the correct number of them, then the analog input value may be going to another variable.
for example, if you have a,b,c,d variables in the serin, and you tell the COM to send in a,c,d,g, by setting CONs to 1, b will get c's value, c will read in d"s value, and d will have g's
DEBUG can monitor the value you program sees; the Dashboard can only report what value the RC sees on the input.
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
Robotics Tournament at Sensors Expo & Conference Kyle Fenton Off-Season Events 4 04-05-2003 12:15
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
