Go to Post If that track ball comes crashing into Exploding Bacon's robot there is literally going to be an Oink Oink BOOM!:yikes: - Koko Ed [more]
Unread 21-05-2013, 21:12
bpulver43 bpulver43 is offline
FRC #1551
bpulver43 is an unknown quantity at this point
Pneumatic Muscle Project
I am building a mechanical arm to replicate the human arm and need to figure out how to control the pneumatic muscles. I want a hand actuated valve that works so that when two muscles are connected to the valve, they operate as an antagonistic pair (think biceps and triceps). I think that a three way toggle or rotary valve will do this but I am not sure. Here is a link to the type of muscle I will be creating: http://www.instructables.com/id/Pneumatic-Muscles/
Any suggestions about what valve would work and where it could be purchased would great, thanks
Unread 21-05-2013, 22:04
Re: Pneumatic Muscle Project
It seems like any of the standard pneumatic solenoids we use in FRC would work fine for this purpose.
Each solenoid has two outputs.
Each pneumatic muscle has a single input.
Use one output per opposing muscle.
When Output A is pressurized, Output B is depressurized, and vice versa.
Unread 21-05-2013, 22:32
FRC #1551
Thanks for the reply. So would a 3 port manual valve like these work as well
http://www.smcusa.com/top-navigation...els.aspx/28743
http://www.automationdirect.com/adc/...s/CVR-437D2-HL
Unread 22-05-2013, 02:42
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Yep, you're looking for a 5-2 valve. Solenoid-actuated 5-2's are commonly used in FRC because you're usually working with double-acting cylinders, which require two inputs.
It has 5 ports:
  • Pressure in
  • Pressure out A
  • Pressure out B
  • Exhaust A
  • Exhaust B
And two positions:
  1. Port A pressurized, Port B exhausted.
  2. Port B pressurized, Port A exhausted.
You could also get away with a 4-2 (the exhausts for A and B are combined instead of separate ports.)
The 5-2 might be more useful than the 4-2 though, as the individual exhaust ports allow you to add two needle valves (or needle-exhausts, McMaster calls them "Flow Control Mufflers") so you can control how quickly (or slowly) each of the muscles actuates.
If you're looking for a hand-operated one, just add that to your search. Good ol' McMaster has a pretty good selection
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 22-05-2013, 08:35
FRC #1551
Thank you very much for the help!
