Go to Post Waiting for the kick off is like studing the molecular structure of grass while being hit on the head by a frying pan - infinitydex [more]
Unread 22-05-2013, 01:16
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Pneumatic Test Stand
I think you are likely going to run into problems powering the compressor with that power supply. The compressor can draw ~20amps on start up and ~10amps when running.
I'm also not seeing any sort of relay to control the compressor. The FIRST legal pressure switch can't handle that many amps. You can use a common automotive relay to control it. wire the pressure sw inline with the relay's coil and you'll be good to go. Look for a universal relay often sold for driving/fog lights, they are typically rated for at least 20a and many are rated for 30a or 40a.
