Go to Post I feel like watching match videos from 2003 could be considered a form of cruel and unusual punishment. - Cory [more]
Unread 02-05-2013, 16:21
Avrum Goldman Avrum Goldman is offline
FRC #3979 (Solaris)
Avrum Goldman is an unknown quantity at this point
Question Pneumatic Test Stand
Our team is looking to set up a pneumatic "test stand".
Objectives:
- Gain familiarity with pneumatic components and function
- Rapidly lash up pneumatic gizmos and test them out (grippers, lifters, etc.)
- Measure performance and validate model/analysis, confirm margin
- Optimize and validate designs BEFORE adopting for the robot design
We need to have some capability to measure pressure, force, position, etc. We will also need some data logging/analysis capability.
Has anyone done something like this that they could share?
Is anyone interested in collaborating on this project?
Unread 02-05-2013, 18:25
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Pneumatic Test Stand
We have a small pneumatics board that we use for testing pneumatic mechanisms. It doesn't have any testing/analysis capabilities though. You can calculate the force using the air pressure in and bore size, unless you just want to test if the cylinders are functioning correctly.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 20-05-2013, 21:10
FRC #3979 (Solaris)
Update 20 May:
I have completed the basic "Air production, storage and delivery modules (see attached photo):
- Power supply from an old computer
- Three air tanks: you can shut off two with a valve
- Three double solenoids (one 24 v, two 12 v) to power up to six actuators
- Manual push buttons to actuate each solenoid
- Quick disconnect for additional loads
Can you guess what my control panel is made from?
Still to do:
- I built a "Lash up board" to quickly try out actuators: Horizontal and vertical peg boards
- I need some sort of "tinker toy" parts quick to assemble arms, gears, cams, grippers, levers, etc.
- I need to have alternate inputs to allow solenoid actuation from the robot cRIO
- I have charged my son (in Electrical Engineering program) to come up with pressure and position transducers, force load cells, and a PC-based data recording system so we can quantify performance and compare designs.
If anyone has good ideas or would like to team up, please let me know!
Name:	Pneumatic test bench in progress May 21st 2013 with labels.png
Unread 21-05-2013, 13:26
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
Question: Where is your regulator? I see the pressure relief valve, attached to the compressor, with a pressure gauge. I presume that one reason for making this system is to mimic a pneumatic system on a FIRST robot.
Suggestion: Make the "stored" pressure (~115 PSIG) one color of tubing, and the working pressure (<60 PSIG) another color. While certainly not required, it can be a good feature when teaching students.
Also, I typically rig up a "pneumatic tree" around the regulator. It has a pressure gauge for the stored pressure, the regulator, and a pressure gauge for the stored pressure attached to each other with brass fittings. (Use double male brass fittings and "T" brass fittings.) This also makes the system easier to explain to the students.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
Unread 22-05-2013, 01:16
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I think you are likely going to run into problems powering the compressor with that power supply. The compressor can draw ~20amps on start up and ~10amps when running.
I'm also not seeing any sort of relay to control the compressor. The FIRST legal pressure switch can't handle that many amps. You can use a common automotive relay to control it. wire the pressure sw inline with the relay's coil and you'll be good to go. Look for a universal relay often sold for driving/fog lights, they are typically rated for at least 20a and many are rated for 30a or 40a.
Unread 22-05-2013, 02:12
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
+1 on this!
Color coding can save you a huge amount of time when diagnosing a problem.
Personally, I would not only color code between stored pressure and working pressure, but between actuators too. (the tubing from one solenoid would be green, next one blue, etc.) That is, if you have that many colors of tubing
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 30-05-2013, 09:39
FRC #3979 (Solaris)
Good call on the regulator. I added it in so the solenoids are at the working pressure of 60 PSI as required. I will experiment with the other suggestions. I wanted a nice "layout" where everything is visible. However, there will undoubtably be line losses that will drive us to us a more compact arrangement. This will be part of the learning experience.
AG
Unread 30-05-2013, 09:41
FRC #3979 (Solaris)
Thanks for the suggestion. I started simple, with a separate manual switch to shut off the pump when at pressure. The next step is definitely to add a relay connected to the switch.
AG
Unread 30-05-2013, 10:10
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Gotta love that improvisation!
Nice work all around.
Jim
Unread 30-05-2013, 10:42
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Have you considered putting something over the air tanks in case of shattering?
Unread 30-05-2013, 11:48
AKA: Jim Grove
Avrum,
A few more tips:
1) You should have minimal line losses. If the pressure drops too fast after you shut off the compressor, check for leaks. Put a little liquid dish soap in a cup of water, and spread the soapy water on the joints. Bubbles will appear at the leaks.
a) For brass-brass joints, snug them up a bit more. CAREFUL: The same quality (malleability) that makes brass good at sealing joints, makes them susceptible to ruining them through catastrophic deformation. Happens when you twist too hard with steel wrenches.
b) For plastic line joints, be sure the lines are cut clean and square, and inserted snugly into the quick-disconnects.
c) For the M7 fitting at the solenoids, be sure to use an allen wrench in the center of the quick disconnect. (AM website: "Fastening method: Internal hex (use allen wrench)")
d) At any threaded joint, you may need to use small strips of teflon tape. Be very parsimonious on using teflon tape, as pieces can break off and get into the valves.
2) Recommend that you build the pneumatic system as close to the FIRST system as you can, including the compressor control system with pressure switch and relay hooked to a cRIO. This can give you the experience of building up a whole system to spec now, and you won't have to learn it during the pressure of build season. If you can, work with a local team to borrow a few parts.
Jim Grove, Mentor
Unread 31-05-2013, 08:04
FRC #3979 (Solaris)
The blue "control panel" was cut from a plastic dustpan! It had the right size, and I liked the design: color, tilted surface. I shelled out for the $4 version rather than the dollar store one for added stiffness!
Kidding aside, I really want all aspects to have a "step by step" approach for ease of trouble-shooting, use, and educational value.
I see a three step approach:
1) Simple: Push the button and watch the piston actuate.
2) Moderate: Program the robot controller to send the signal to activate the piston.
3) Advanced: Transducers to measure air pressure, position and force vs time, with data logging so we can analyse the mechanism for force/timing margins, and correlate with the design/analysis objectives.
AG
Unread 31-05-2013, 08:09
FRC #3979 (Solaris)
I wasn't aware that this could be a problem! I am definitely interested in safety. Would a plexi-glass sheet be sufficient?
AG
Unread 31-05-2013, 08:12
FRC #3979 (Solaris)
Avrum,
A few more tips:
Jim,
Thanks for the tips. We have "thin" teflon tape, which is a god-send. I will definitely work my way up to connecting the cRIO for control.
AG
Unread 31-05-2013, 10:42
AKA: Jim Grove
AG
Read this:
http://www.usfirst.org/roboticsprogr...-safety-notice
Also, there was a picture posted (somewhere) of the plastic tank remnants. I have been unable to locate said picture. Also, there were a few threads posted on CD, commenting on the FIRST safety post.
Jim Grove, Mentor
