Go to Post [You know you've overdosed on FIRST when...] When you discover that the cure to the swine flu is "oink oink BOOM!" - Katie_UPS [more]
Unread 22-05-2013, 12:25
Pauline Tasci's Avatar
Pauline Tasci Pauline Tasci is offline
Rockets and Robots
FRC #3476 (Code Orange)
Pauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond repute
Re: Ball Shifter vs other gearbox
I have to agree with Aaron, how do you know what your ideal robot is if you don't know what you need?
FIRST gives you six weeks to build a FULLY functioning robot.
Not just everything but the chassis.
As well I do not think it is a bad thing to become familiar with different drive systems, it will give you more options next year and you will expand your knowledge. But designing something for next year and not knowing what you need might set you up for failure.
Team 3476 Code Orange- 2014-? ~ Head Mechanical and Design Mentor
FIRST Orange County 2015-? ~Regional Planning Committee Member
Beach Blitz 2016-? ~ Event Chair/Director
FIRST Volunteer-2010-?
Team 589 Falkon Robotics- 2010-2013 ~Captain, Driver, Outreach, Mech Lead
CD Moderator~ Always feel free to PM me.
Facebook
Unread 22-05-2013, 13:31
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Exactly.
Also I never mentioned, though Pauline did, that offseason is a good place to practice things, like new transmissions. If you've never used two speed gear boxes then I suggest getting a pair of Ball Shifters and testing them out. Program them the way your driver would want, learn to find the best gear ratios, etc. Hopefully this will help you design you drive trains in future years.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 22-05-2013, 19:17
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Originally Posted by akoscielski3 View Post
Here's your biggest problem. You are designing your chassis months too early for next season. You need to find out what your ideal speed/speeds will be. Your strategy may not require even going around defense next year, like this year if you were a FCS you didn't have to be really fast, but a cycling robot needed to be really quick.
Exactly.
I think his methodology is correct. Determining which speeds would be ideal for this year should yield a system to determine speeds for other years. Consequently, 766 and 3309 design drive systems to accept a range of gear ratios using data from previous games. We also have a range of ideal gear ratios that work for most years. Hence why 1114's kit-bot on steroids is so good.
You both touch on practicing drive trains, I would add testing. 766 ran their drive train last year through an off season event and more. So this year 766 and us had great confidence in the drive's durability. When running a new gearbox, things you have to ask, does the rest of my drive promote durability? What will break first, the wheel? and what sort of preventative maintenance you need?
I don't think you can design your drive train too early. Having the extra time invested to promote durability is well worth the effort. As long as you factor in reCADing during the build season, making adjustment to reflect the new game and time it takes to build a drive, I don't see a strong enough argument against starting a design now. I started next years drive during week 6 of the competition season.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 22-05-2013, 19:46
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Our 6-sim drive was a lot of fun this year, but probably too fast for what we were doing. Since we were a full-court robot, we only used it twice, once to get into the feeder station, and once to go hang. However, it was a lot of fun for plowing past defenders, or doing our own defense. Take a look at this, about 40 seconds in.
Unread 22-05-2013, 21:40
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
You forgot the video, I would love to see it though. We are experimenting with 6 CIM this offseason.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 22-05-2013, 21:47
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
My steps to drivetrain:
  1. Determine speed(s) as dictated by strategy
  2. Determine wheel size as dictated by strategy (i.e. big wheels to cross bump)
  3. Choose/make the best gearbox & chain reduction to meet your chosen speed with your given wheel size
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 22-05-2013, 22:27
Andrew Lobos Andrew Lobos is offline
FRC #0225 (TechFire)
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
I think this is the video Wren was talking about: http://www.youtube.com/watch?v=cUvA_t9H_K8
