Go to Post For those of us in the north, a water game turns into an ice game, which becomes Lunacy. And I don't think any of us want that. - Kimmeh [more]
Unread 22-05-2013, 16:58
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: Good motor practices
Make sure you don't run them above the recommended voltage. Also, don't overtighten the mounting screws, or if you have tapped screws in a gearbox, don't tighten them into the motor on the other side. Please don't drop them either, as that de-magnetizes the motor.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 22-05-2013, 17:49
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
Be very careful if you try to press something onto the shaft or to press the raised ring on the end of the CIM itself into anything. If you press the shaft of any motor, it is hard not to ruin the bearings. If the other end of the shaft is exposed, you can support it and even use it to help hold the shaft perpendicular to the press by using a piece of metal with a dimple drilled into it to keep the shaft from wandering. The raised ring on the end of the CIM is part of the endcap which can be fractured pretty easily in a press -- avoid any tight fits here.
Unread 22-05-2013, 19:36
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Have you ever actually broken one? I have been part of a few *ahem* questionable mounting practices, including using a hammer on the end of the CIM to get a gear onto the shaft.
Unread 22-05-2013, 20:02
AKA: Allen Nuttle
FRC #4080
I've seen it done, both types of trouble. The minibot motors were fairly easy to mess up by pressing the unsupported shaft.
Unread 22-05-2013, 20:04
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
some past team member milled/hobbed a gear on the shaft of a CIM, I have no idea why but it still works.
2016: FRC 865 Mentor
Unread 24-05-2013, 16:49
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Older CIM motors had a hobbed gear on their shaft. The last year I saw them was 2002. In 2003 they switched to key way. That might explain what you saw.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 23-05-2013, 20:47
Micah Chetrit's Avatar
Micah Chetrit Micah Chetrit is offline
FRC #3276 (NSR)
Micah Chetrit is on a distinguished road
Can you please explain how this works? I always tried not to drop motors for other reasons, but how does a drop affect magnetism?
Unread 23-05-2013, 23:08
ttallo's Avatar
ttallo ttallo is offline
FRC #0230 (Gaelhawks)
Team Role: Operator
ttallo is an unknown quantity at this point
A magnetic is comprised of many small magnetic fields called domains basically electrons spinning in the same direction with their poles aligned. This creates a magnets pull. When you drop a magnet these domains slowly become misaligned with each drop and eventually you no longer have a magnet.
Unread 24-05-2013, 13:02
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Before the magnet losses its magnetic "power", the motor will have mechanical damage like shaft gets bent or the casing cracks. With a bent shaft, the motor power is wasted, the bearing wears out and possibly seize and may result in motor stall and finally burn out. A cracked casing can be like a ticking bomb, you will never know when the guts or the whole motor falls out!
Unread 24-05-2013, 13:55
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The magnets themselves are brittle. Very tight clearance between the magnet and the rotor. Magnet flakes from being dropped will lock up the rotor.
You don't see/smell the magic smoke from the cims because they are sealed. Al has posted pictures on another thread of what a smoked cim looks like.
Unread 24-05-2013, 14:33
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
A few links worth looking at:
Here's a link to some details of how CIM motor's heat up when loaded to their maximum mechanical power.
Here's a link to some measurements my lab made of CIM motor starting current. Special thanks to Russ Ether for his help with that testing. Here's another link to his white paper on how several FRC legal speed controllers limit the CIM motor's starting current.
Here's the link to Al Skierkiewicz's thread (mentioned above) on failure of a CIM motor due to extended, hard practice driving. Don't try this at home, or if you do then plan to replace the motors before your next competition.
Richard Wallace
since 2003
