Go to Post Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs. - sanddrag [more]
Unread 24-05-2013, 09:00
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: pic: Our 2011 Mini-bot Tetrix motor grave
Actually, these weren't all burned out in minibots. Our FTC teams have toasted their share as well.
These motors let out the nasty smelling smoke if you stall them for even a few seconds. I've complained to Pitsco that these motors need to be improved, but they are in denial that it is a problem. I was told that they work fine as long as you use them for what they're designed for. Of course I disagree. Hopefully we'll track down the funding to test out some Matrix motors and see if they're more durable.
Unread 24-05-2013, 09:48
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Originally Posted by Nemo View Post
...Hopefully we'll track down the funding to test out some Matrix motors and see if they're more durable.
Be advised that Matrix motors are of a different voltage, have integrated encoders and a custom connector that includes power and the encoder signals. Nothing that is a deal breaker for your potential experiments. Just wanted you to be aware that they are not a 1 to 1 comparison.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 24-05-2013, 10:36
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
Yeah, I figured changing the motors would end up changing quite a few other components on the robot. But if they're better, it ends up being a pretty significant benefit. Thanks for the info.
Unread 24-05-2013, 11:00
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
I counted 20 motors, $600, poof!
We have/had (not sure of the status) a similar pile...
For a team that has never used a 2 speed gearbox, vision processing, mercaium wheels, or canbus due to funding...
Yet we still have two 1.3ish second minibots that have not moved, since the Kettering Kickoff for Rebound Rumble.
Such a shame.
The sooner we get behind schedule, the more time we have to catch up.
Unread 24-05-2013, 18:12
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
I divided up our team's tetrix remnants and had a grab bag ceremony at last year's FTC CT tournament. I offered the motor carcasses in a seventh bag, and it was snapped up by some enterprising youngster. I wished him well with the parts as the chances they would/will be useful in FRC future are slim indeed.
IMNSHO - GDC/FIRST failed big-time with the mini-bot challenge. They should have required construction of minibots by a registered FTC team and braced themselves to withstand the inevitable whining by FRC teams complaining of a lack of FTC resource in their area. Point would have been promotion and wider recognition of FTC.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 24-05-2013, 18:15
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
If your goal is to have no Canadian* teams with minibots, that sounds like a fantastic idea.
*and other areas where FTC doesn't exist
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 24-05-2013, 20:15
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
That was suggested at some point here on CD. Then the Trolls came out. We have a few around here ya know. Something about "if I wanted to do FTC i would have done FTC." There was some raging and a bit of whining in there too, but that was the gist of it. Oh, and throw in a "FIRST is anti IFI/Vex" in there for good measure.
Unread 26-05-2013, 01:54
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
//Edit: Can't seem to be able to delete my post, only edit it...
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 24-05-2013, 09:51
Data Nerd
FRC #0079
As long as what they were designed for is to make a boat load of money by selling a cheap motor for $30 and letting it cook off if you stall it at all.
Unread 24-05-2013, 10:15
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Straight talk is refreshing. I could not have stated this better.
Life lesson: you do not always get what you pay for -- sometimes you get less than that.
Richard Wallace
since 2003
Unread 26-05-2013, 03:03
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I can't find the original (it's somewhere here on CD), but I had to repost:
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
