Go to Post Just a modest request for folks NOT to put 3000-pixel-wide pictures inline in the forum. A link to the big picture works just as well while keeping the text readable. Thanks. - Rick TYler [more]
Unread 24-05-2013, 12:25
ferrari77 ferrari77 is offline
FRC #2583
ferrari77 is on a distinguished road
Center to Center with belts
Our team is prototyping a drivetrain in the offseason and we wanted to try out building it with exact center to center spaced wheels with timing belts
Last year we used bearing blocks and tensioned them but it would be a lot simpler if we could do away with the tensioning
I have a few questions about this
Once we calculate the correct distance and build it, how do you get the belts onto the pulleys. Our previous experience shows that the belts have to be pretty tight so it seems that it would be very hard to put the belts over the flanges on the pulleys
Also, how precise does it have to be built? All of our sheet metal work is done using a hand operated sheet metal punch and sometimes holes can be off by as much as 1/32 of an inch (less than 1/16) Would it be better to always err on the side of farther apart rather than having the belts be loose?
This will be a completely sheet metal drivetrain by the way
Any other advice about doing C-C belts would be appreciated
Unread 24-05-2013, 12:57
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: Center to Center with belts
When building exact c-to-c drivetrains with chains, we put the chain over the sprocket, then line the sprocket up with the bearing block, then skewer the whole thing with the shaft. When using belts I'd think the approach would be similar, though a bit more difficult because you need more tension in the belts.
Unread 24-05-2013, 14:13
steelerborn's Avatar
steelerborn steelerborn is online now
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
http://www.sdp-si.com/cd/default.htm
Good enough is the enemy of anything great!
team 1671
Unread 24-05-2013, 14:22
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
We did GT2 5mm x 9mm belts this year with C-C + .005 in our west coast drive train and loved them.
http://25.media.tumblr.com/6a0f1b587...cgvo5_1280.jpg
However we used tube and CNC milled them, down to probably +/- .003 tolerances. We never had an single issue after 2 regional.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 24-05-2013, 14:27
Nate Laverdure's Avatar
FRC #2363
This thread has a lot of useful information on how to do exact c-c spacing with belts.
Unread 24-05-2013, 14:48
craigboez's Avatar
Mechanical Engineer
Very nice arrangement, we're working on something similar for an offseason project. Two questions:
1. Do you mean you milled the GT2 pulleys? If so, can you provide some details on what is required to do such a thing. Are there specific CAD tools, special cutting tools, etc that make life easier?
2. It sounds like you didn't have any issues with belts skipping/ratcheting, even though 15mm belt sounds like a "safer choice" for a drivetrain. Using the 9mm did you drive it hard, go from full forward to full reverse, push much, etc without issues?
Unread 24-05-2013, 15:33
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Take a look at the Andy Mark 2013 KOP drive train.
In the past we've built a tensioned belt setup and then last year we used the Andy Mark Setup. It is a excellent drive setup. Easy to assemble and maintain and we had no belt ratcheting whatsoever despite playing mostly defense. We were geared to 10'/sec , 6 wheel dropped with 4 CIMs. 6" kit wheels
The width of the belts, the size of the pulleys and the dead axle make assembly easy.
I was surprised to see so many 2013 kit bots in the Curie Finals. The Kit bot on Steroids is a excellent drive train.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 24-05-2013, 17:38
Mk.32's Avatar
AKA: Mark
Thanks Really happy with this drive.
What I meant in my post was I CNC milled the bearing holes in the rails so that the C-C distance was a really tight tolerance. (I would think 1/32 off would be to much).
However I did machine my own pulleys, more info: http://www.chiefdelphi.com/media/photos/38380
In short just a tiny (3/32th) square endmill + 3/8 alum plate + cnc. The pulley cad was downloaded from SDPSI and I used just my regular CAM software to come up with the tool path.
We did not have any issues with skipping and ratcheting. And the people that have seen me drive can vouch we pushed the drive as hard as we could, with doing all the above. Also to test I pretty much rammed into a test wall and stalled the motors and the belts still didn't ratchet.
Unread 25-05-2013, 01:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I used XL timing belts and pulleys from McMaster and the SDP-SI calculator and I would call it a very loose fit, but it never skipped. I would have liked the fit to have much less slop though.
Unread 25-05-2013, 09:14
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
The industrial answer is to make the perimeter that encompasses the OD of each pulley and the tangents to those edges equal to the inner perimeter of the belt, so that it fits over all pulleys at the same time. Then, either cam one shaft into location (ie - slide) or use a cam-style idler roller for belt tensioning (cam followers work great for this).
Of course, if you don't want to have a separate tensioner and you want the shafts to be fixed in place, you can have one of the pulleys have either no flange or a removable flange. After all, you typically only need flanges on every other pulley.
A really good resource for timing belt information is http://www.martinsprocket.com/2001/SecK.pdf#J2
It has center-to-center charts, rules of thumb, engineering calculations, and design criteria.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 25-05-2013, 12:14
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
We had fixed flanges on all of our pulleys this year and it worked fine. The trick is to put the belt on the pulleys before putting the pulleys on the shafts. Keep the pulleys in the same plane as you slide them onto the shafts and it will work fine.
-Mihir Iyer
Unread 25-05-2013, 13:17
FRC #1836 (MilkenKnights)
What were your robot dimensions(in case we go back to 28x38 next year)
Unread 26-05-2013, 19:06
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
We use a worksheet to calculate C-C distances for axles driving chains or belts. This works really well without requiring tensioners for short runs (<=6"). Longer runs require tensioners or empirical determination. Link to worksheet below:
http://www.chiefdelphi.com/media/papers/2715
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 28-11-2013, 00:25
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Just to clarify for my own knowledge, there should be little to no performance issues using 9mm wide belts compared to using 15mm wide belts (like those in this year's KoP) assuming they both have the same tooth profile? I'm currently working on a practice sheet metal chassis using belts and I'm trying to make the wheel wells as thin as possible but I don't want to compromise performance for space. Thanks,
Jesse
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 28-11-2013, 01:52
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Jesse
Not necessarily true. The maximum torque that can be put on a belt varies proportionally to its width. If you're right on the edge in terms of how much torque that can be on the belt, the switch from 15mm to 9mm definitely makes a difference in whether it will ratchet or not. If you want to be sure, check the Gates website. They should have some nice tables that give all of the relevant torque and speed information.
Just keep in mind that for FRC, your FoS or duty rating will probably be much lower than 1 (i.e., it can take more torque than what's on the table). Those belts are designed for hundreds of thousands of cycles, something they'll never see in FRC, so we can probably get away with more torque than they were designed for. Adam Heard probably has a more exact number, as he's built a lot of belts drivetrains before.
-Plutarch
