Go to Post Don't you know anything about programming? It's a black box; you don't need to know how it works. - Chriszuma [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 26-05-2013, 06:06
yajzse yajzse is offline
yajzse is an unknown quantity at this point
Potentiometers in LabVIEW?
Good day!
Our professor instructed us to simulate a robotic hand using LabView and Solidworks. He said we should construct real-time controller using a potentiometer. Being new to these softwares, I really don't know how to start. I have read several articles for beginners and somehow got a little knowledge about LabView, but reading the articles that discusses programs using potentiometers confuses me. These are what I cannot understand.
Is there a potentiometer component available in LabView or do I need to have a real potentiometer? If so, how will I integrate this with LabView?
Is the output a varying voltages? If not, how will I make the output one?
Thank you very much.
Unread 26-05-2013, 12:25
Re: Potentiometers in LabVIEW?
A properly connected potentiometer will produce a voltage that is proportional* to the shaft angle.
* It's actually a function of the amount the shaft has been turned. If it's a linear pot and one end is at ground, the y-intercept is zero and the relationship is strictly proportional.
