Go to Post Although I've never oxy welded myself, I know it is doable - jamie_1930 [more]
Unread 26-05-2013, 09:34
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: OPR-computation-related linear algebra problem
Couple of things.
In a PDE class I tool for CFD, we had to solve really large sparse matrices. the trick was to never actually store the entire matrix. However ours was much more structured and more sparse. Not sure if I can apply something similar. in this case.
What is the accuracy you are looking for. Could use some iterative methods for much faster results. You can pick an accuracy of 1e-1 (inf norm) and be fine I think for OPRs.
Loading it into my GTX 580 GPU right now to get some values. Will do that with and without the time taken to load it into the GPU memory and back.
-Borna Emami
Team 0x27
