Go to Post We put our alumni to work. That either benefits all or drives them out for good. :) - Wayne C. [more]
Unread 26-05-2013, 09:07
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Smart Dashboard Crashing
When we open the smartdashboard executable after several minutes it crashes. Did i configure something wrong? Also when we open smartdashboard through the driver station we cant add a camera. Any ideas?
Unread 26-05-2013, 11:00
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Smart Dashboard Crashing
The SmartDashboard has I believe a memory leak while running the camera. When it runs out of allocated memory the entire thing crashes.
The SmartDashboard that comes with the Driver Station does not include the camera widget. You have to set the "default" dashboard to your standalone SmartDashboard that does have the camera widget. To do this follow the instructions starting at "Locate Driver Station Configuration" and ending by following the instructions for "Modify the DashboardCmdLine" at this guide http://wpilib.screenstepslive.com/s/...sion-installer
Unread 26-05-2013, 13:07
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Ok thanks i will try this
