Re: Team 2052's Mecanum Showcase!
If you've posted it elsewhere, please direct me, but what did you do differently that meant you did mecanum well? Was it placement of center of mass, some sort of suspension on the wheels, specially stiffened chassis, gearing, control scheme, or something else? It's a great video, but it doesn't give much insight into your design.
Thanks, |
What happens when someone catches you sideways? I saw a few spin-offs, but sometimes you seem to prefer turning rather than crabbing, even when it exposes you to transverse pushing. Nice, guys! |
How much did your robot weigh?
Do you know the ratio of the gearboxes you were using with the 8 inch mecanums? Is there any special software or sensors you guys used in conjunction with the drive system such as a gyro or field oriented control? |
I'd take those equations: a tank's going to have basically double your CoF. AM lists their mecanum as 0.6 sideways (0.7 axial), and we've got nitrile at around 1.2 AM puts HiGrips a bit lower, while VexPro puts Versas right there. Colsons are even higher--I recall people modifying colsons to like 1.5. (EDIT: colson link) |
That actually just made me think of another point. We were playing defense once (we don't do it too often remember). But a robot was using a ramming technique to break our static friction and every time they backed up to ram we drove sideways towards them and actually gained ground on each hit haha. I'm not claiming mecanum is better than the higher traction tank drive bots at sideways collisions, they're almost certainly not. What I was saying is that it's tough to add in force of the mecanum in the sideways direction, along with static friction of the rollers, along with slipping of the rollers, and get a correct equation for mecanum because I don't have those numbers. I bet every team has a different slip in their rollers making it hard to calculate as well. I do think that our mecanum was better than many of the robots we faced at taking sideways hits. Some of the mecanum bots were much, much worse at taking sideways hits than tank robots so that's not a blanket statement. Those robots are probably the ones people picture when they think of collisions as well. Maybe in the off season we can do some testing ![]() |
#7
This provides a clear benefit, as there isn't much a tank drive robot can do to counter it. They can't rotate and keep pushing us nearly as well as we can slip away from them, and it would take a lot more maneuvering for them to reposition themselves in front of us as we slip away. Our reaction to a head-on pushing match is never "keep pushing back and hope we win." Our reaction is to slip out and around the robot. |
#8
Here's what I think you are implying: It is harder to push a mecanum robot sideways when said robot is trying to resist the push by attempting to push back than it would be if said robot simply had its wheels (wheels, not rollers) physically locked. Have I correctly inferred your implication, or have I misunderstood? |
#9
Again the benefit of that is when a robot breaks contact with us to try to ram we continue to push against them and we back up as they do, not allowing the ram and gaining ground. You are the numbers expert here Ether, feel free to give some numbers! ![]() |
#10
Would that be correct? It seems counter-intuitive that force from a motor could overcome slip -- I'm imagining Lunacy-style wheels, where more force from the motors just meant more slip. |
#12
Roller slip will vary by specific DT, but not nearly as much as between mecanum and tank in general, and it's not helpful in strafing. It's also (thanks to Ether), not overly difficult to model the description, at least to the point of illustrating its negative effect. As the paper explains, the friction that keeps rollers from slipping adversely effects mecanum's strafing traction. If this is what we're talking about, I don't understand the implication that driving the wheels produces more tank-like results. *Apparently also lower, to a factor of sec(α)--Ether's paper is great. |
#14
Again we were never trying to push in the sideways direction. Our video does not show us winning too many big pushing matches. Mecanum allowed us to avoid those situations. We did not choose mecanum for its pushing power haha, nor do we generally use it for such things. The video is just meant to show some examples of how we used mecanum to our benefit this year, and to hopefully show it's not as weak of a drivetrain choice as it is in most CD'ers minds. No one (hopefully) chooses mecanum for traction purposes. We just wanted to highlight some of our match videos because people cited us as a good example of mecanum. |
#15
Also, I seem to have distracted the thread from Mr. Elston's very good questions: Quote:
