Go to Post The toughest part about that Chairman's Award was the fact that someone was cutting onions in the stands near 558/on the field while it was being read out. At least that was the excuse I'm going to use ;) - esquared [more]
View Poll Results: What drivetrain did your team use this year
4 wheel tank 51 17.29%
6 wheel tank 158 53.56%
8 wheel tank 24 8.14%
10+ wheel tank 0 0%
Swerve Drive 4 1.36%
Omni Drive 6 2.03%
Mecanum Drive 35 11.86%
Tank Treads 0 0%
Articulating Drive train (butterfly, nonadrive, octocanum) 10 3.39%
Other 7 2.37%
Voters: 295. You may not vote on this poll
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 27-05-2013, 12:49
Re: What Drivetrain?
Originally Posted by MICHAELABICK View Post
About them being the best, what do you qualify as WCD.
The "standard" definition of a WCD is a 6WD drop-center, cantilevered wheels, live-axle, center directly driven off of the gearbox (usually a 2-speed gearbox), outside wheels chain-driven off the center axle.
I don't necessarily agree that WCD is the best of the tank drives, partly because it does take some precision to make and thus might be rather difficult for some teams, but it is up there if a team can build it properly.
Unread 27-05-2013, 16:56
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
What if your team switched drive trains through the season...
No, it didn't end well.
Unread 28-05-2013, 08:25
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Last year, our team changed drivetrains at Championships. Try to avoid that.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 28-05-2013, 19:06
Actually... Switching drivetrains is something you could get away with, IF you've planned correctly. For example, if you've got the extra hole(s) drilled already, it'd be relatively simple to go from 8WD to 6WD, or vice versa, or 4WD to 6WD, or 4WD to mecanum (with a pair of transmissions added). Planning correctly means that you built the robot to be able to switch--though it does not necessarily mean modularity.
330 did that back in 2005--the competition robot had an extra set of transmission slots so we could swap to mecanum from 6WD if we thought it was a good idea. The testbed--a Kitbot--ran mecanum. We didn't have the weight that year to switch. To this day, 330 has yet to run mecanum on a competition robot.
Unread 28-05-2013, 19:10
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Originally Posted by Teamcodeorange View Post
3. Our drive base is very simple and easy to fix, just a piece of extrusion, bearing blocks, chain, and wheels. (Don't trust hex bearings.)
When you say extrusion, did you use something other than the normal 2X1 tubing?
Also whats up hex bearings?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 28-05-2013, 20:24
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The one year we did mecanum (logomotion) we machined our frame with holes to easily be able to add dropped center wheels if the mecanum didn't work. We were happy with it's performance because the ease of strafing to hang tubes and that games rules limiting defense.
This year we made major drivetrain changes at our second regional and we were inspected and driving by 2:00 on Thursday. It can be done if you plan properly and practice the change, a second robot is invaluable for this.
Unread 28-05-2013, 21:48
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
Not sure if this is what he was getting at, but I'll give it a shot. There have been a couple of issues with hex bearings this year. One of the main ones was simply supply. For a long period of time this season, hex bearings were completely sold out wherever you looked. There were also problems with the hex itself, which was often oversized or undersized.
1/2" hex bearings are sold out at VexPro and West Coast Products (although their store is down for maintenance). They used to be sold out at AndyMark, although it looks like they're back in stock with an order limit of 10.
2009-2013: Student, Team 100
2013-????: ?
Unread 29-05-2013, 00:50
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Yes, we use 1/8" 1 x 2 aluminum extrusion.
The hex bearings are a problem because they shouldn't exist, at least not for 4 dollars. It seems that the vex pro ones are just normal bearings broached to fit a 1/2" hex shaft. The problem with this is that the added force on the corners of the shaft crack the inner race and render the bearing useless. This happened to use every couple hours of driving in practice, and a 2 times in competition. If you use hex parts, do it with round bearings if at all possible. (you can machine down a 1/2" hex shape on 5/8th shaft)
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
Unread 29-05-2013, 01:02
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Has anyone else had this problem with hex bearings?
I'm curious because I know they're other teams that run WCD's with hex bearings and to my knowledge they don't have any problems.
How exactly were your bearings configured on your WCD? What was your bearing block setup like? How close together were your bearings? Did you do anything very different from the stereotypical WCD in your drivetrain?
-Adrian
Unread 29-05-2013, 01:24
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
-Adrian
There was a lot of discussion about their issues this build season.
Here is an example of one thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=111513
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 29-05-2013, 01:58
AdamHeard's Avatar
Lead Mentor
Interesting. We have a lot of time on both our practice bots, and 4 events on comp. All on 1/2" hex bearings from AM; no failure or issue whatsoever.
Unread 29-05-2013, 02:42
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I've never seen a hex bearing that came "out of the tube" with significant runout issues or race damage. We've bough bearings from AM, WCP and VP. That said, poor (read: >~.008 too tight) press fits, mishandling, or excessive loads can damage the bearings. Especially damaging is when you press on the inner race while pushing the outer race into a too tight press fit.
I've never seen using 1/2" hex broached bearings per se as a problem, but there are a couple of hypothetical workarounds. First, you could turn down the 1/2" hex to 1/2" round to fit in a bearing (this would only really work if the round bit was at the ends, so it wouldn't work right for a traditional WCD). Also, you can press a 1/2" hex broached 1/2" ID 3/4" OD brass bushing into the inside of a 3/4" ID ball bearing. We've done somthing similar with 3/8" hex in a 1/2" bearing. A little excessive, but it would let you use 1/2" hex unmodified in a bearing that didn't have the inner race broached. Others have mentioned fine foxes as well.
To answer the origional question, we did 4WD skid stear. It was solid but not excellent.
-Plutarch
Unread 29-05-2013, 11:55
FRC #3476
Originally Posted by DampRobot View Post
I can only talk for the VEXpro bearings. I forgot to mention that the entire first batch we got was nowhere near concentric, the second batch was still not great but we didn't have the time to wait for more. The Andymark/WCP might not have the problem of cracking, but the VEXpro ones sure did. Next year we will definitely be using round bearings.
Unread 31-05-2013, 22:38
Niezrecki's Avatar
Niezrecki Niezrecki is offline
AKA: Justin Niezrecki
FRC #1124 (ÜberBots) + FRC #5686 (Wirecats)
Niezrecki has a spectacular aura aboutNiezrecki has a spectacular aura aboutNiezrecki has a spectacular aura about
We use Six wheel drop center.
Unread 01-06-2013, 12:44
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
3539 used a 6w WCD this year. The past two years, we used 8 wheel standard tank drive, but this year we tried WCD to open up the inside of our frame for our ground intake and we were EXTREMELY happy with the results. Our drivetrain was easy to build, easy to maintain, rugged, light, and extremely nimble. We had a 1/8" drop on the center wheel, direct driven from our gearboxes. Custom 6" aluminum wheels with roughtop tread. We were geared for about 13 fps, so we were able to drive around most other robots on the field. We were very satisfied with the WCD style and will likely be visiting it in the future.
Here's a little video of our robot driving around at Troy. It was fun to watch this thing go
http://www.youtube.com/watch?v=gnDLFystS1Y
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
