Go to Post The final product, the inspiration, it all that matters. Awards and championships are just bling. - artdutra04 [more]
Unread 27-05-2013, 20:43
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: OPR-computation-related linear algebra problem
Hi Ether,
I compiled it with Borland C++ 5.5 and ran it [...] It took 80 seconds
That's quite a large difference in runtime. I compiled mine with Visual Studio 2010. I had wondered if VS was able to do any vectorized optimizations, but I don't see evidence of that in the Disassembly.
If your code took only 3 seconds to run on your machine, but 80 on mine, I'm wondering what the Rice algorithm would do on your machine.
If I'm reading the pseudocode you posted correctly, I think I'm using the same algorithm (I got mine from the formulae on Wikipedia), the only difference I could find is I didn't handle the case of roundoff errors leading to slightly negative sums for the diagonal elements and I do some of the sums in reverse order, but unless there's some drastically bad cache effects I don't see that impacting the runtime.
Makes me wonder what you may have done better in your coding of the algorithm.
EDIT: Changing the order of the summations got me down to 2.68 and changing to in-place computation like your code got me to 2.58. Beyond that, any improvements would seem to be in the way the Pascal compiler is generating code.
Best,
FRC 766, 2015-, Mentor
