#16
Re: 2013 Robot Dimensions
We were configured long, 6 wheel tank, 32.5 x 23.75. The length was largely driven by the 31 inch nanotubes and wheels.
#17
Did people actually do the "walk all the way around" thing? I thought that was a original intent, but then we were told (both as an inspector and as a mentor), that we'd just measure each side and add. The walk around's more accurate though. |
#18
We were 28W*26L. (No, it's not because I'm a Wave fanboy)
If I had to do it again, it would probably be 24W*30L Last edited by Chris is me : 28-05-2013 at 15:28. |
#20
So keep the rule, regulate the procedure. |
#21
In the end, though, I would personally be comfortable with either method as being "good enough". After all, what difference is a 1/4" going to make if you're a little over? It just mean's you're going to be spending some time and effort getting under (by filing the corners), without really changing your design. If we miss that 1/4" by measuring the sides and doing some math, I wouldn't really think that a team gets any sort of competitive advantage. I'd be more worried about inspectors confusing themselves trying to do the math under pressure while standing in front of a team! |
#22
We would have liked to go with a 38:28 ratio, but couldn't. We had a shooter proto w/ hopper in week one that we liked that was 26 inches wide. So we made the robot 26.5 inches which left the length to 29.5 inches.
We built the bot to the full spec of 112" knowing we could keep a tolerance to .125 inch over the entire bot. Our plan was that if we came in to long on the perimeter to take a smidge off the corner bumper mounts. |
#23
I like small 'bots, and I cannot lie. ![]() |
#24
The key point, however, is that with a smaller footprint it makes it very, very hard to build a robot that can do everything. As a result, teams have to prioritize and choose what they'll do. From a strategy perspective, you end up with matches that play very differently based on what each robot is capable of doing. Who does the blocker try and stop, the shooting robot or the climbing robot? If you have 3 short robots, how do you stop the FCS you're going against? This goes directly against what we've seen the past few years. Last year, everyone mostly stayed on their side of the field, shot as many baskets as they could and balanced a bridge. The only question was how many robots would be on that bridge. The year before, you were split with two robots putting up tubes and one playing defense for most alliances, and everyone had an identical minibot to deploy by week 2. By forcing the "elite" teams to make choices in their design, we create a much better competition overall. |
#27
There's something to be said for the measurement of 112". It's a 28x28 cube. It means any four-sided robot, regardless of how it is built, WILL fit through a standard door. Changing it to 132" would allow the possibility for errors.
Personally, I didn't mind smaller robots. Packaging wasn't easy, but it wasn't the reason we made any of our big design decisions really. The way robots move across the field when they are smaller was also better, less traffic and more scoring in general. |
#28
I had somehow missed that robot! that's a pretty cool (and very different!) way of shooting!
#30
525.
