Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 28-05-2013, 15:24
rhodes rhodes is offline
FRC #3236
rhodes is an unknown quantity at this point
Dimension for pyramid
We do not have a practice pyramid...
however we do have a bar that we have used that is 30" off the ground. We want to place the 60" bar the proper distance away from the 30" bar.
What is the dimension from the imaginary vertical line that passes through the 30" bar to the imaginary vertical line that passes through the 30" bar?
Can someone that built a practice pyramid please check by using 2 plumb bobs and see how far apart they are.
(Is it 12.12)
Unread 28-05-2013, 16:10
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Re: Dimension for pyramid
The pyramide's side's angle is 68deg IIRC, you can check in the manual.
Because of that the distance between the pipes' centers would be 30*cot(68deg)=12.12in approx, like you wrote.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 28-05-2013, 17:02
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Yes, it is a 68 degree angle.
The manual will tell you everything you need to know. Pyramid drawings start on page 34 of the Game Specific Drawings.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
