Go to Post sigh, I started wondering why we weren't there than I realized it was in California. Thats a bit of a road trip... - Raumiester2010 [more]
Unread 01-02-2003, 16:33
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
3D Wire Mesh
Hey all, I'm having some real trouble making the wire mesh for the playing field, it's the contraints in Inventor that are really getting me. If someone could possibly upload a piece of thier mesh onto the forums that would help greatly, or just tips will help too. Thank you!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 01-02-2003, 17:36
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
i can post one in 3ds format...
maybe autocad or something else you can pull into inventor...
if you want it, pm me.
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 01-02-2003, 22:41
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Just draw a circle, and pattern it out to the appropriate length. Then select all of those, and extrude them all to the right length.. that is one side. Then start a new sketch, and change the plane. Draw another circle, pattern that out, and extrude them all. You should have a nice wire mesh model.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 02-02-2003, 01:19
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Inventor 5 or 6
If your using Inventor 5 or 6 for the playing field you could just make a very thin rectangle for the mesh, then apply a texture to it. There might even be a texture included that would look pretty good.
Purdue Alumni
Cummins, Inc.
Unread 04-02-2003, 12:49
FAKrogoth's Avatar
FAKrogoth FAKrogoth is offline
FAKrogoth is an unknown quantity at this point
Re: Inventor 5 or 6
One of the textures IS a wire mesh. As long as you don't care that the mesh can only be about 1/2", it should be fine. As for something more exact, you could do it with lots of extruded circles, and one constrain "flush" on each side.
Never underestimate the power, number, or magnitude of stupid people. - me
Unread 04-02-2003, 14:00
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
the easiest way to make wire mess won't be in inventor. It will be in 3ds max. You can model it Just make a box...and by adjusting the amount of height and width segments you'll get a believable effect... Add a material to that...(wireframe) it's at the top of the material editor..in a check box. You can modify the parameters in the extended parameters dialogue...it works out quite well.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
Which wire mesh will be used? Jacqui Sutton Rules/Strategy 1 07-01-2003 00:51
Can tread protrude through the wire mesh? Randy Ai Rules/Strategy 1 06-01-2003 17:17
Motor wire sizes Tim Skloss Motors 5 13-02-2002 07:44
wire question James Crivellone Electrical 1 13-02-2002 07:32
