Go to Post There should be no teams yelling "robot". - RoboMom [more]
Unread 30-05-2013, 08:45
Re: No driver station
Originally Posted by ninjosh97 View Post
I was looking at the cRIO flashing tool and under the labview option, I saw an (always run deployed code on startup) check box. I assumed that meant it would run with no driver station. If not, what does it do?
That just tells the cRIO to run your user code whenever it's booted.
The cRIO OS and FRC image with all the safety interlocks will run no matter what.
You won't be able to bypass the FRC safety stuff, otherwise what good would it be?
You'll have to have a Driver station app connected and Enabled just to get the robot to move, but you could add additional controls by your IR remote.
