Go to Post It's not a problem, it's a feature! - smokescreen [more]
  #31   Spotlight this post!
Unread 29-05-2013, 01:57
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Re: OPR-computation-related linear algebra problem
Sorry I'm a bit late to the party.
I'm running Octave 3.2.4, so an older version than flameout
Hardware is Dell E6420 laptop (CPU i7-2640M @ 2.8GHz) Win 7 64bit
octave:2> N = load('N.dat');
octave:3> d = load('d.dat');
octave:4> tic; Ns = sparse(N); toc
Elapsed time is 0.136 seconds.
octave:5> tic; r = Ns \ d; toc
Elapsed time is 0.096 seconds.
octave:6> tic; r = N \ d; toc
Elapsed time is 0.921 seconds.
So solving the sparse matrix is around 230ms and direct solution is around 900ms.
  #32   Spotlight this post!
Unread 29-05-2013, 13:23
Originally Posted by RyanCahoon View Post
EDIT: Changing the order of the summations got me down to 2.68 and changing to in-place computation like your code got me to 2.58. Beyond that, any improvements would seem to be in the way the Pascal compiler is generating code.
Thanks for doing this Ryan.
Interestingly, the Pascal and C++ compilers I used are essentially identical. Only the front ends are different (for the different languages).
Is it possible that the difference in timing is due to the differences in the memory access due to the data structures we used?
  #33   Spotlight this post!
Unread 29-05-2013, 13:30
Originally Posted by Greg McKaskle View Post
There is a toolkit called "Multicore Analysis and Sparse Matrix Toolkit", and they ran the numbers using that tool as well.
Greg,
What machine & OS was used?
  #34   Spotlight this post!
Unread 29-05-2013, 14:17
Originally Posted by BornaE View Post
Loading it into my GTX 580 GPU right now to get some values. Will do that with and without the time taken to load it into the GPU memory and back.
Did you ever get a chance to do this?
  #35   Spotlight this post!
Unread 30-05-2013, 01:24
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Using MATLAB 2012a on a Intel Core i7-3615QM
Ryan,
Could you edit your post to indicate what O/S you are using?
Windows 7 x64 Home Premium
We're both using 8-byte floating point numbers. Assuming Pascal stores a multidimensional array in a contiguous memory block, we're basically using the same data structure - the only difference being that I'm only storing the elements below the diagonal and I believe you store all the elements of the matrix (at least, this is the way that I wrote the read/write code). Maybe this would affect caching.
For comparison, I compiled your code using Free Pascal and the Cholesky decomposition ran in 11.9 seconds on my computer.
FRC 766, 2015-, Mentor
  #36   Spotlight this post!
Unread 30-05-2013, 07:35
I haven't used Pascal in a long time, but seem to remember it storing 2D arrays with different elements adjacent. It was column-major and C was row-major. The notation isn't important, but accessing adjacent elements in the cache will be far faster than jumping by 20Kb to pickup up the next element.
Greg McKaskle
  #37   Spotlight this post!
Unread 30-05-2013, 08:09
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
I don't have direct access to my desktop at the moment, I was doing that remotely with Logmein however for some reason I lost the connection and have not got it back yet.
I tried it on a GTX555M with only 24 cuda cores. It was 50% slower than my laptop processor(Core i7 2670QM quad core running at 2.2GHz)
I will post here as soon as I get to my desktop.
I was able to get 0.015 seconds using sparse matrices, however GPU processing does not support sparse matrices directly. I doubt that I can get any faster results than that.
-Borna Emami
Team 0x27
  #38   Spotlight this post!
Unread 30-05-2013, 09:29
laptop Core i7 2670QM quad core 2.2GHz...
Matlab, Octave, SciLab, Python, or something else?
Linux, Windows XP/7, 32 or 64 ?
  #39   Spotlight this post!
Unread 30-05-2013, 09:42
BornaE's Avatar
Matlab 2012b
here are the results
Normal Matrices(CPU and GPU(555M))
Using inv(N)*d:
CPU 1.874s
GPU 2.146s
using N\d:
CPU 0.175s
GPU 0.507s
Sparse Matrices(Only CPU)
Using inv(N)*d:
CPU 0.967s
using N\d:
CPU 0.015s
Cannot get sparse matrices into the GPU easily.
The times are only for the solve operation.
-Borna Emami
Team 0x27
  #40   Spotlight this post!
Unread 30-05-2013, 13:34
I was thinking the extra computation required for this might be the culprit:
#define ELEMENT(M, i,j) (M[(i)*((i)+1)/2+(j)])
  #41   Spotlight this post!
Unread 30-05-2013, 14:23
Just installed Octave3.6.4_gcc4.6.2_20130408 on this computer.
Results:
GNU Octave, version 3.6.4
Octave was configured for "i686-pc-mingw32".
octave:1> tic; d = load('k:/MyOctave/d.dat'); toc
Elapsed time is 0.0625 seconds
octave:2> tic; N = load('k:/MyOctave/N.dat'); toc
Elapsed time is 90.0469 seconds
octave:3> tic; r = N \ d; toc
Elapsed time is 1.03125 seconds
octave:4> tic; r = N \ d; toc
Elapsed time is 0.953125 seconds
octave:5> tic; Ns = sparse(N); toc
octave:6> tic; rs = Ns \ d; toc
Elapsed time is 0.1875 seconds
octave:7> tic; Ns = sparse(N); toc
Elapsed time is 0.046875 seconds
octave:8> tic; rs = Ns \ d; toc
Elapsed time is 0.171875 seconds
Anybody know why Octave takes so long to load N ?
Load N times, all on the same computer:
Delphi....0.6 seconds
C.........1.3 seconds
SciLab....1.7 seconds
RLab......3.7 seconds
Python....6.5 seconds
Octave...90.0 seconds
  #42   Spotlight this post!
Unread 30-05-2013, 15:13
LV times were on this computer
Win 7 Professional 64-bit
Xeon CPU E5-1620 3.6GHz
16G RAM
Greg McKaskle
  #43   Spotlight this post!
Unread 30-05-2013, 21:17
RLaB is not a contender for fastest speed, but it's definitely the tiniest linear algebra app out there. It weighs in at under 1.5MB.
Makes a wonderful pop-up for that quick calculation, or for high-school students just learning linear algebra.
Very easy to use... and free.
Welcome to RLaB. New users type `help INTRO'
RLaB version 2.1.05 Copyright (C) 1992-97 Ian Searle
This is free software, and you are welcome to redistribute it under
certain conditions; type `help conditions' for details
> tic(); N=readm("N.dat"); toc()
3.66
> d=readm("d.dat");
> tic(); x=N\d; toc()
28.5
> tic(); x=solve(N,d,"S"); toc()
14.5
The second solution method (x=solve(N,d,"S")) tells RLaB that the matrix is symmetric, so it uses LAPACK subroutine DSYTRF (Bunch-Kaufman diagonal pivoting) to solve, which cuts the time in half.
  #44   Spotlight this post!
Unread 30-05-2013, 21:52
RyanCahoon's Avatar
I tried reversing the indices and it took 59.1 (vs 11.9) seconds. A couple other websites say Pascal is row-major.
I was worried about the same thing. In the most recent version of the code I posted, that macro is only used once (not in a loop) to calculate a pointer to the end of the matrix.
  #45   Spotlight this post!
Unread 31-05-2013, 09:06
Is anybody else running Octave on a machine with 32-bit-XP Pro?
Are you having the same 30 second delay for Octave to load, and 90 seconds to load the 12MB N.dat file?
