Go to Post Well, air conditioners when pointed inside the house make it cooler. So I figure if EVERYONE turns their air conditioners on full blast and just point them out the window, we should more or less get rid of this "warming" nonsense. - Mike [more]
Unread 30-05-2013, 02:54
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Laser Cutter And FRC
I recently got a membership to TechShop in the Bay Area, a hackerspace that has a fairly extensive shop. One of the many machines they offer for members to use is the Epilog Laser Engraver. I was wondering what experiences people have had with this machine in specific, and with laser engravers in general for FRC use. Were there any cool or innovative uses you found for this tool? What kind of parts did you use it to make, and how did they perform?
The first specific use that came to my mind was using this machine to make plastic gearbox plates, out of either polycarb or ABS. Has anyone tried this? What kind of tolerances can this type of machine hold? Is this a good/bad idea?
If I do end up trying to make plates like this, I'll be sure to share the results with the community.
-Plutarch
Unread 30-05-2013, 04:19
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
Re: Laser Cutter And FRC
I've used their laser cutters for a few things, I wouldn't suggest using them for transmission plates. I haven't tried any decent tolerance parts on it, but from visual inspection of other 1/4" things I've done, taper is gonna be a issue. Also the kerf does not always appear to be constant, as at the speeds slow enough to cut 1/4" delrin, heat will build up in non consistent ways. Overall I think your going to have pretty big issues cutting transmission plates with reasonable tolerances. I'd suggest just using their router instead, as that should give you no issues holding tolerances. Good Luck
EDIT: Also you can't cut polycarbonate on those laser cutters, as they do not have adequate filtration to handle the toxic gases they create.
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 30-05-2013, 04:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Pretty sure they won't let you cut polycarb due to fumes.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-05-2013, 07:41
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Generally the laser cutters can be pretty accurate (about .005, depending on machine/settings) but that's only the center point on the laser. Other issues mentioned above will prevent any highly delicate work to be done.
My general decision on laser cutting VS Milling/watterjet:
Does it need to be done fast?
Is Acrylic/Delrin/Wood okay?
Are the tolerances okay?
Typically, a gearbox plate has a no in all three of those questions!
That being said, I'm uploading pictures now of entire robots I've made on a laser cutter for WPILib as well as classes.
Unread 30-05-2013, 09:26
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
We used the TechShop lasers to make timing belt pulleys for our drivetrain this year. We use 9mm GT2 and our pulleys are made out of layers of 1/8" acrylic that are then attached to each other with acrylic cement. These pulleys are very cheap and they allow us to avoid having to wait for timing belt pulleys. One of the biggest benefits to making our pulleys this way is that we can use the laser to cut the hex which we have no other way of doing. The pulleys have not had any issues throughout the entire season. Its is also really easy to bring spares in case something happens as they are both cheap and light. We also used the laser to make the timing belt pulleys for our pick up. This was interesting because one of the pulleys was mounted on a piece of abs tube. The pulleys we cut for that were very flimsy as the bore size was not that much smaller than the outer diameter. After attaching them to the abs with the same acrylic cement, we have not had any issues with them breaking. We have access to a router at the school, but things that require a hex or other special patterns, we use the laser as long as the part will not be taking too much load.
-Mihir Iyer
Unread 30-05-2013, 10:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We have a Versalaser that is handy for all sorts of things. It sees very little use for the FRC robot itself, but we use it for small mini-sumo robots for class projects and for engraving giveaways. We have done 1/4" ABS on it but it did not turn out great. Right now I have a problem where the laser is weak and struggling to cut 1/8" acrylic. Need to check it out and get it fixed.
Unread 30-05-2013, 10:19
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
I have seen a lot of teams using them for hex spacers and such. This year we used the engraver to cut wheel treads because it was much easier than doing them by hand or on the band-saw. Also when you buy the big rolls and need to make the notched shape for the new performance wheels it makes it much easier and cheaper.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRSTŪ or my affiliated team.[/center]
FRCŪ Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 30-05-2013, 10:23
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
We've used a laser cutter from my college for many things over the past few years.
  • Delrin Spacers
  • Belt sprocket flanges
  • Wood and acrylic prototypes
  • Frisbee shooter skid plates
  • Sensor mounts
  • Other sheet delrin and ABS parts
Don't expect to use it for major structural components, or to do the kind of work a sheet metal shop would, but it's great for a lot of little things. Good tool to have in your back pocket.
They make cool small robots as well.
Unread 30-05-2013, 11:06
-Mihir Iyer
Hex patterns can easily be milled/routered. You just need to open up the corners.
dtengineering's Avatar
AKA: Jason Brett
Laser? Talk to FRC 1899 Saints Robotics. They know laser.
Jason
Unread 30-05-2013, 11:14
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Lens might be dirty. At least with the epilog, the lens needs to be cleaned every so often.
We love our laser cutter. We use it for tons of stuff, mainly with ABS. Our team considered ABS gearbox plates, although we did not actually do it because we were using supershifters for the first time and did not want to take the risk. We still believe that it would work out, though.
We did use ABS for other things on our robot this year. All of our sprockets were made using it, and worked really well. Plus they were lightweight.
We had linear actuators consisting of a double pulley moving up and down aluminum c-channel. The entire pulley module was made out of ABS, and although we had problems with them, the problems did not stem from our choice to use ABS.
We then created an ABS template which we used to lay it on top of all the layers of our wood and polycarb arm and drilled in all of the holes. Without the template, it would have been nearly impossible to manually sketch out the dimensions of each and every hole.
Our frisbees traveled down a curved path on our arm. We used stacks of .25in ABS as rails to guide the frisbees. There is absolutely no other way in our capabilities that we could have machined such a thing.
Our wrist was 75% ABS. Besides increased machining capabilities, this also allowed us to have a lightweight wrist.
Finally, we lasercut our "daisy" floor pickups using rubber. What the rubber basically did was whack the frisbee into the arm.
In sum, we basically used the laser cutter and ABS for 2 main reasons: to give our low resource team machining capabilities comparable to high resource teams and to create lightweight components. Next year, we have even bigger plans for this amazing machine.
Unread 30-05-2013, 11:53
Chris is me's Avatar
AKA: Pinecone
Cutting polycarb on a laser is messy (toxic fumes) and with many thicknesses doesn't always leave a clean cut. It can be... melty. I wouldn't really consider it.
I would not make any competition robotics parts out of acrylic, which is the material most plastic laser cutters are used to cut. There is nothing good that can come out of acrylic on an FRC robot.
I don't know a lot about ABS / delrin laser cutting, but it's much more doable than polycarbonate.
I don't think lasering a gearbox plate on this machine is going to be the best idea. If you're at a good hackerspace, they have higher precision equipment (e.g. a decent router / mill) for this purpose.
Unread 30-05-2013, 12:11
fiona.crush1011 fiona.crush1011 is offline
AKA: Fiona Hanlon
FRC #1011 (CRUSH 1011)
fiona.crush1011 is an unknown quantity at this point
Besides making things for your robots there is a lot you can do for spirit and for sponsors. Our team personally does not have a laser but some of our friend teams do. This year they made us key chains with our name and number as well as little name tags for all our kids. They also made us plaques to give out to our sponsors. Each plaque was engraved with the sponsor, their level (depending on how much they donated), a little sentence about thank you and our logo. The sponsors loved them! They really like having something that they can hang up in their office and show off to everyone that comes in.
Unread 30-05-2013, 12:35
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Damp,
If you wanted to make a nice compact 3 CIM ABS/Delrin gearbox housing with a PTO port. Think about repackaging the VexPro Ball shifter design.
I would be willing to lend you a hand and get you some Engineering and CNC machining time. I wanted to make a video for our team to show how a Solidworks design is imported to Gibbs Cam and how the geometry is used to create the tool paths and G code and how the part would be made on the CNC mill.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 30-05-2013, 13:51
gracie.'s Avatar
gracie. gracie. is offline
forgot the heat shrink...
FRC #2399 (The Fighting Unicorns)
gracie. is an unknown quantity at this point
We've cut our electronics board with the exact same machine as you now have access to (epilog laser engraver) for two years now. We used 1/4" ABS both times, and learned some lessons between the two. The first year (last year), we had lots of issues with fire/smoke and the lens of the laser. Burnt ABS has just a lovely smell! The lens would get clouded, we'd have to replace it, etc. I was in the shop til Midnight and my mentor was there longer finishing it (I got called out by my parents).
The key with 1/4" ABS is to make multiple passes (like 4, maybe 5 just to be safe) at a lower power to minimize the burning and the lens issues. I could get the exact settings we used for you if you ever want to use this thickness of ABS. The electrical team is in love with the stuff, because modification is easy, and laser cutting it makes assembly really smooth and we can just plan and execute the whole thing from CAD. I now have a(n unhealthy) love of lasers. Hopefully I can save you some trouble if you're ever using this material.
I know my team's cut 1/4" acrylic on one of these (or similar), but that was before my time.
2399: The Fighting Unicorns! - Alumna, team sister | Dean's List Finalist 2013
Anyone need a mentor in west LA?
