#91
Re: Video of Mecanum Drive Running Circles Around 6 Wheel Drives
http://www.youtube.com/watch?v=fWYN5xVIyzw&t=11m1s Quote:
#92
We have liked mecanum for several years because of the ease of lining up with field elements -- like the feeder slot. (We won a regional in 2010 and didn't this year, but despite that I can say without hesitation that this is the best robot we've built so far. That said, we did use octocanum, not straight mecanum, but we rarely dropped the traction wheels at FLR or Buckeye.)
#93
http://www.youtube.com/watch?v=Ogy65hEPIXk 2052 used mecanums better than I have ever seen |
#94
At a recent meeting we had our robot from this years game with a 6 wheel drive and the mechanum bot out.The kids driving the mechanum couldnt get around the 6 wheel bot enough or by anymeans run circles around it. also if our six wheel cought the mechanum and started pushing it it was all over. so in the end mechanum is manuverable but its not great
#96
[/quote]
Well-practiced Mecanum <= Well-practiced 6 Wheel Drivetrain Well-practiced Mecanum >= Good 6 Wheel Drivetrain Little-practiced Mecanum < Good 6 Wheel Drivetrain[/quote] this is just abouat the best thing i have read...good drivers and practice make a great difference |
#97
(I'll post videos later, I'm not able to get to them now)
I was a driver for 1259 this year, and we used 4 wheel mecanum. Although I still feel we would have been a better robot with tank drive, we used the mecanum as well as we could. In Wisconsin I was able to outmaneuver some of the opposing alliances (with tank drive) with a combination of strafing and spinning to get to the pyramid so we could start our 3 level climb. Would I have been able to do that with tank? Probably...chances are with tank we wouldn't get into situations where we had to really try hard to outmaneuver other robots. But the mecanum allowed us to move in dimensions that tank robots couldn't, and in the small, cramped side lanes on either side of the field near the pyramids, I think that additional degree of freedom helped a little bit. A quick aside--this has befuddled our programmers for some time now. Our robot strafes almost perfectly on smooth floors, like tile, or the traditional wooden gym floors. Yet, on the field at both Wisconsin and Duluth, strafing was slow, and required a lot of manual adjustment on my end to do well. Trying to strafe with just one joystick meant turning while moving in one direction. It was our first year doing mecanum, so if anyone's able to point us in the right direction, that'd be swell. We thought it was the individual spindles on the wheels slipping, but I've seen other robots use 6" mecanum wheels from andymark no problem. |
#98
How can you reasonably expect anyone to take your response seriously when you didn't care to take theirs seriously?
#100
To be fair, mecanums have a really really good installation effort / cool factor ratio.
#101
http://youtu.be/rJoqeiuX3lA?t=1m43s
4096 handled the defensive bots well in this match but again, it doesn't necessarily support the mecanum > 6WD argument, just an example that was requested. |
#102
Which make them perfect for demo robots, assuming there will be a flat floor.
#103
The last truly flat field--no under-carpet bumps or over-carpet bumps--was not 2011. 2009 doesn't count (and had a bump anyways--there was carpet exposed at the edges). 2007, if you weren't climbing a ramp; 2005 if you count the ramps. Yep, 2005. Until you factor in the loading-zone triangles, in which case we haven't had a truly flat field since before automode--in 2002's Zone Zeal. Last edited by EricH : 30-05-2013 at 19:27. |
#104
DDDHaha, okay, point taken. But I would venture to say that your team was an exception to the rule at pushing robots up the bridge in Rebound Rumble, n'est-ce pas? And congratulations on your 10,000 lakes performance! |
#105
Proof that a 6wd robot is superior...
![]() http://www.youtube.com/watch?v=Pu1VCYP4doo I don't see them using mecanums... ![]() |
