Go to Post If everyone spent half as much time reading and understanding the rules as they do complaining, arguing, and disagreeing about rules, we might not even be having this discussion. - AmyPrib [more]
Unread 30-05-2013, 23:12
Photo Storm Photo Storm is offline
FRC #2811 (Skyview Stormbots)
Photo Storm is an unknown quantity at this point
Driver Station Suggestions
My team is developing a new driver station for use in the upcoming seasons. In my knowledge our team has not had a formal driver's station that goes on the shelf so we just carried the laptop and controller to the driver's area. I have seen many different driver station with different layouts. I was wondering what features are useful, useless, or nice to have. Thank You
Unread 30-05-2013, 23:17
Re: Driver Station Suggestions
Velcro on the bottom to match the driver's station. Might save you from having to dive to catch the board during a match.
Light weight. You do have to carry the board.
Handles of some sort. You do have to carry the board.
Unread 30-05-2013, 23:42
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
I definitely agree with EricH on the board being lightweight and having handles. I would also add:
a. make sure the handles are comfortable to carry (we've made that mistake)
b. if this person who will primarily be carrying it has a small arm span, don't make it so long that they can't carry it (read: i was short drive coach with short arms)
c. i would suggest attaching the pieces (joysticks, laptop, etc) to the board in some way for stability. We normally use Velco so we can pull stuff off and stick it back on.
d. aesthetics can be nice. We've use 80-20 on our robots a lot so our drivers console uses 80-20.
The best picture I could find of our 2013 one (https://www.facebook.com/photo.php?f...type=3&theater)
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 31-05-2013, 07:02
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
One suggestion I had here was build your driver station and carry it around all day at school, setting it up for each class. If you can move it down the hall and get it ready before the bell rings, you got a winner. To which I should add -- carry it around safely all day, and not end up as a bulky deadweight.
Some students finally finished our driver station for this year's competition. It was a plastic suitcase (like a professional camera case type) with foam inside cut out in the shapes of the controllers. A small laptop was attached inside, on the top part, so it could hinge open, with a connector to the field made thru the wall. A nice "W" plate in the back (facing the field). Velcro on the bottom.
Unread 31-05-2013, 12:36
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
I agree to the lightweight and portable aspect but i think there is one bigger thing you need to be sure of.
Make your driver station is useable and comfortable to use for driving the robot at competitions. If you have a driver station that you don't like because you aren't comfortable with using it, is a bigger issue. Ex tilting your joy stick (the whole thing) forward to make it easier for you will benefit you a lot.
A driver station that prevents you from getting disconnected from your robot will help too. Sounds silly? How can your driver station prevent you from being disconnected from your robot? Well ask 1114. Last year at GTR West in Finals 2 2056 ran into the driver station wall, the ethernet became disconnected and they were their sitting died on the field. This year they designed a simple driver station that would stop that from happening again. They put foam around the ethernet, and joy stick controller plugs so that any impact or small movement wouldn't unplug the cables.
Also another thing that we liked this year was that we put a strap on it, that way we don't have to hold it, it is just being held by a strap around your neck. We used a guitar strap for ours, and it works really well.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 31-05-2013, 12:41
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Use a better laptop than the classmate if possible.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 31-05-2013, 17:20
Tmaxxrox97's Avatar
Tmaxxrox97 Tmaxxrox97 is offline
FRC #2512 (Duluth East Daredevils)
Tmaxxrox97 is an unknown quantity at this point
The driver station that my team has used for the past two years is a piece of carbon fiber, which was donated by one of our main sponsors, with our laptop and joysticks velcroed on. This is the lightest, nicest looking driver station we have had.
If it is small enough and light enough you shouldn't need any handles, but thats your choice.
The main thing to remember is that it has to work. One thing to do is ask your drivers to see what they want/ like. They are the ones who will be using it the most so if they don't like it then it doesn't do you much good. Just something to keep in mind.
Name:	driver station.jpg
If it (the robot) is strong enough to do the task, it should be able to handle any abuse a 16 year old with a joystick can throw at it. --MrBasse
Unread 31-05-2013, 17:27
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
Adding velcro to the bottom of your joysticks and laptop is a great idea! We do that too.
And, as EricH said earlier, make it light!
I've also always wanted to try to make a folding driver station so it can easily be fit through doorways.
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 31-05-2013, 17:31
Sam Drake's Avatar
Sam Drake Sam Drake is offline
What goes up...
AKA: Samantha
FRC #4452 (FIRST Noble Team)
Team Role: Driver
Sam Drake will become famous soon enough
Our driver station was made during the week before our first competition. It was a simple piece of 3/4 plywood cut to 30" by 8". We use some old Logitech controllers, driver on the left, operator on the right, each with a piece of Velcro on the bottom of the left handle. To carry the station we made 2 handles from scrap extruded aluminum that were bolted together and then filed smoothly to avoid any cuts. The computer was attached to the station by two large pieces of Velcro that kept it firmly in place, yet not too much so that the computer could be removed if need be. Another thing about our wooden driver station, it only took an hour to cut the wood, give it a quick sanding, spray paint the top white, spray paint a stencil of our logo on each of the controller spots (color coded for the driver and operator controllers) and then attach everything by Velcro, and bam! Driver station
Who ever said girls don't like robots?
Unread 31-05-2013, 18:00
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
If you velcro down the standing joysticks (as opposed to storing Xbox controllers in velcro loops), be cognizant of the velcro's affect on joystick movement. Depending on the joystick, mapping and the driving style, the slop of the velcro can non-negligibly affect responsiveness. Sometimes it might have a positive smoothing effect; sometimes you see drivers slamming joysticks around while the entire thing lifts 1.5" off the baseboard. A lot of the fast DT drivers I see that use joysticks will have them rigidly mounted and/or sandwiched in between layers of material (often polycarb) for this reason.
We've grown the prefer an old briefcase, modified to stay within the 12" when open, though we're still working on improving it. Ours holds the laptop, drive team binder (scripting options, documentation), the 2 Xbox controllers, spare cables (Ethernet and the Xbox adapters), and the hardware for our driver's head's up display. It's also nice to be able to close it all up and latch for transport.
On last check, make sure your laptop and any other electronics can vent and cool properly. Laptops are not big fans of velcro over their vents. (We didn't actually learn this the hard way, but we picked it up from the robot side of things.)
Unread 31-05-2013, 18:09
Nate Laverdure's Avatar
FRC #2363
Originally Posted by Siri View Post
...the slop of the velcro can non-negligibly affect responsiveness..
Ever since being exposed to FLL, I like to use Dual Lock for this kind of application. Makes things snap nicely into place.
Unread 31-05-2013, 22:54
Siri's Avatar
Dare greatly
Just don't let your drivers rip them off like those shelves in Senior Solutions. Like many an FLL robot, there are FRC drivers out there with an amazing capacity to lift up anything not nailed down, particularly when on the end of a conveniently joystick-sized lever arm.
Unread 01-06-2013, 00:30
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Seconding this big time. Our old driver station was very wide, with handles on the very ends. I'm 6'1", and I was uncomfortable carrying it. It was made of 80/20, so we ended up cutting down the long bars of it, and brought it down to maybe three feet wide, or a little under, and now it's fine, if a little heavy.
I once played with the idea of getting a sheet metal shop to cut and bend a single sheet of aluminum into a drive station, but never made concrete designs for it. Maybe I'll CAD it up now that I have some free time.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 01-06-2013, 04:37
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
About a year and a half ago, I was interested in taking a crack at designing a custom driver station out of sheet metal aluminum. This was primarily a design exercise for me to learn about sheet metal, but the final CAD looks pretty cool. I took my inspiration from 192's driver station.
If you'd like, I would have no problem giving you my CAD files. Just let me know.
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 01-06-2013, 20:24
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
We have something that looks cool, but isn't the most practical one out there. On the other hand, our root cart accommodates the driver station under the robot, so it's okay.
