Go to Post Chit Chat is frivilous but CD would be a colder place without it. - Koko Ed [more]
  #46   Spotlight this post!
Unread 31-05-2013, 09:22
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
Re: OPR-computation-related linear algebra problem
I can check after work in the lab this evening if no one gets to it first, Ether!
  #47   Spotlight this post!
Unread 31-05-2013, 10:30
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Originally Posted by RyanCahoon View Post
I tried reversing the indices and it took 59.1 (vs 11.9) seconds. A couple other websites say Pascal is row-major.
Long, long ago I was the support for a Pascal compiler that ran on the Unisys A-Series. That compiler did Row major, since that was the underlying architecture of a stack machine. A 2D array consisted of an array of pointers, each pointer referencing a row. Once you got the row, it was fast to "walk the row" since the elements were contiguous in memory.
Walking the matrix in col order caused two memory accesses per read, one for the pointer (and the time to do the reference fetch) and the read of the data elements. You could see a -10x reduction in speed doing column order vs row order. -- Thanks for the "back when" reminder.
Ether: Just for grins, I tried RLab on our 16 way cluster. For some reason I'm not getting responses to tic()/toc(); What Windows OS are you running RLab under?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
  #48   Spotlight this post!
Unread 31-05-2013, 10:57
32-bit XP Pro SP3 on a Pentium D 3.4GHz
Don't forget to leave the semi-colon off the toc() if you want it to display.
Here's the code:
diary("output.txt");
tic();
d=readm("d.dat");
toc()
tic();
N=readm("N.dat");
toc()
tic();
x = solve(N,d,"S");
toc()
Here's the output.txt file:
// RLaB diary file: output.txt. Opened Fri May 31 10:53:02 2013
tic();
d=readm("d.dat");
toc()
        0
tic();
N=readm("N.dat");
toc()
      3.8
tic();
x = solve(N,d,"S");
toc()
     14.5
If you run it interactively, by cutting-and-pasting the code directly into the RLaB window (or by typing the commands at the RLaB prompt one at a time), here's the output that will display on the screen:
Welcome to RLaB. New users type `help INTRO'
RLaB version 2.1.05 Copyright (C) 1992-97 Ian Searle
RLaB comes with ABSOLUTELY NO WARRANTY; for details type `help warranty'
This is free software, and you are welcome to redistribute it under
certain conditions; type `help conditions' for details
> tic();
> d=readm("d.dat");
> toc()
        0
> tic();
> N=readm("N.dat");
> toc()
     3.67
> tic();
> x = solve(N,d,"S");
> toc()
     14.4
  #49   Spotlight this post!
Unread 31-05-2013, 10:59
Thank you.
  #50   Spotlight this post!
Unread 31-05-2013, 14:46
> tic();
> d=readm("d.dat");
> toc()
     21.9
> tic();
> N=readm("N.dat");
> toc()
     28.8
> tic();
> x = solve(N,d,"S");
> toc()
     34.8
And right, if you do toc(); you don't get the output. Which isn't wasn't what I expected.
Xeon 2.93 Ghz cluster. But this code may not be doing any multithreading.
  #51   Spotlight this post!
Unread 21-06-2013, 15:10
I just got a new computer at work with a Xeon E5-1620 and a Quadro 4000 GPU (256 CUDA cores). Using Matlab 2012b:
CPU Invert and Multiply: 1.4292s
CPU Linear Solver: 0.22521s
CPU Sparse Linear Solver: 0.034423s
GPU Invert and Multiply: 0.537926s
GPU Linear Solver: 0.218403s
Loading the N matrix into the GPU was 1.890602s.
Creating the Sparse Matrix for N was 0.032979s.
