Go to Post By the way, a piece of advice to all those who haven't gone to Manchester for Kickoff before: Go. It's something you have to do at least once in your time in FIRST. - Billfred [more]
Unread 31-05-2013, 13:19
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
pic: WPILib Gearsbot 2.0 Side View
Unread 31-05-2013, 13:22
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: pic: WPILib Gearsbot 2.0 Side View
Originally Posted by BEEKMAN View Post
...This allows the robot to fit into a carry-on sized suitcase for safe travel to demos by the WPILib team...
That's one compact robot! Though I'm not sure how easily it would make it through a security checkpoint if you ever took it with you to an airport.
Is the frame made out of polycarbonate or some kind of acrylic or something?
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 31-05-2013, 15:54
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
I think your right about the suitcase issue.
Also, if you read the end of the post it says that:
acrylic kits
Which would imply that it is acrylic.
Unread 31-05-2013, 16:36
AKA: Brendan McLeod
Yup, its acrylic!
The robot was actually taken from WPI to St. Louis as a carry on with no issues! Part of the design challenge was to make every component air-line safe (battery, pneumatics, *clean wiring*, etc.)
WPI Robotics Engineering & Mechanical Engineering Class of 15
iRobot Mechanical Engineering Intern
Unread 31-05-2013, 17:02
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Reminds me of this
Unread 31-05-2013, 19:16
cbale2000's Avatar
AKA: Chris Bale
Yup, its acrylic!
I'm astonished the TSA didn't give you any issues. Even if it is designed to be air safe, the TSA has been known to get freaked out by much less (just seeing the thing on an x-ray I would think would raise some eyebrows).
Either way, pretty impressive.
Unread 31-05-2013, 19:44
AKA: Brendan McLeod
Don't forger its much smaller when packed! And totally see-through haha, they can see everything
Unread 01-06-2013, 01:30
Joining the 900 Meme Team
FRC #0079
Actually, I've flown my fair share of weird stuff. I flew with 12 pretty big servos, a couple batteries, and a ton of misc PCBs. They didn't say anything about it. I think from getting my ticket to at the terminal at DTW was something like 10 minutes and most of that was saying goodbye to my parents.
