Go to Post Why assume a full trophy case and spreading the message of FIRST (mentoring rookies) are mutually exclusive? Team 16 supported 6 rookies this season and earned 5 banners - I am equally proud of both. - Meredith Novak [more]
View Poll Results: What drivetrain did your team use this year
4 wheel tank 51 17.29%
6 wheel tank 158 53.56%
8 wheel tank 24 8.14%
10+ wheel tank 0 0%
Swerve Drive 4 1.36%
Omni Drive 6 2.03%
Mecanum Drive 35 11.86%
Tank Treads 0 0%
Articulating Drive train (butterfly, nonadrive, octocanum) 10 3.39%
Other 7 2.37%
Voters: 295. You may not vote on this poll
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 01-06-2013, 13:48
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: What Drivetrain?
To the people selecting "other", could you explain? Thanks!
  #32   Spotlight this post!
Unread 01-06-2013, 14:44
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Our robot: http://www.chiefdelphi.com/forums/sh...=3397+Serenity
It runs two wheels in the front, a floating omni-wheel in the back. It does not really fit into any of the categories that were provided, I believe it is called a "kiwi" drive, which is not on the list.
If you want reason as to why we went with this design, all of the details are in the thread linked to earlier.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
  #33   Spotlight this post!
Unread 01-06-2013, 14:54
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
A kiwi drive has 3 omni wheels all driven offset at 120 degree angles from each other the only team i know of that did one this year was 1425 but im sure there are others i havent seen. you can kind of see the drive in this video http://www.youtube.com/watch?v=jWGYa...ature=youtu.be
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
  #34   Spotlight this post!
Unread 01-06-2013, 22:44
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
"Other" = no drivetrain.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
  #35   Spotlight this post!
Unread 01-06-2013, 22:46
UAH Class of 2019
We called our a "stingray" drive, due to the shape of the frame. I was just told by someone that it was kiwi, thanks for clearing that up.
  #36   Spotlight this post!
Unread 02-06-2013, 08:38
The inverse kinematics for Kiwi are very simple and are shown here on one page.
  #37   Spotlight this post!
Unread 02-06-2013, 15:40
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by Adrian Clark View Post
Has anyone else had this problem with hex bearings?
I'm curious because I know they're other teams that run WCD's with hex bearings and to my knowledge they don't have any problems.
How exactly were your bearings configured on your WCD? What was your bearing block setup like? How close together were your bearings? Did you do anything very different from the stereotypical WCD in your drivetrain?
-Adrian
Yes. We destroyed probably a half dozen bearings in a non-loaded low speed application. We ended up not using that particular mechanism on the robot. However, the incidents of failure left us with a very low opinion of the current generation of hex-bearings.
Our application was single shaft non-cantilevered (supported by bearings at both ends). The bearings blew out sideways after the races cracked.
  #38   Spotlight this post!
Unread 02-06-2013, 16:56
DampRobot's Avatar
Physics Major
AKA: Roger Romani
That's amazing... I've never seen anything like it. We used hex bearings, and even Vex Pro hex bearings, on very high axial load, high torque and cantilevered shafts without any problems. Perhaps there was a bad set?
-Plutarch
  #39   Spotlight this post!
Unread 02-06-2013, 18:01
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Interesting. Were these were vexpro bearings?
  #40   Spotlight this post!
Unread 02-06-2013, 18:59
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
The VexPro hex bearings are complete garbage. All the other parts from vex pro are well made, and designed with attention to detail, but the hex bearings are awful. We have an older robot for demonstrations that has a transmission that uses a hex bearing (not on a cantilevered shaft). For 6 years and thousands of cycles in competition and at demonstrations, the original hex bearing worked. Then, we took apart the mechanism for cleaning, and we decided to try out the vex pro hex bearing. After 3 cycles of the arm, the bearing failed completely.
  #41   Spotlight this post!
Unread 03-06-2013, 10:22
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Same as us. Bad bearings, don't do that.
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
