Go to Post So your gearbox failed, and your first course of action was to post about it CD? This is an interesting failure recovery plan. :) - JVN [more]
View Poll Results: What drivetrain did your team use this year
4 wheel tank 51 17.29%
6 wheel tank 158 53.56%
8 wheel tank 24 8.14%
10+ wheel tank 0 0%
Swerve Drive 4 1.36%
Omni Drive 6 2.03%
Mecanum Drive 35 11.86%
Tank Treads 0 0%
Articulating Drive train (butterfly, nonadrive, octocanum) 10 3.39%
Other 7 2.37%
Voters: 295. You may not vote on this poll
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 02-06-2013, 18:59
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Re: What Drivetrain?
The VexPro hex bearings are complete garbage. All the other parts from vex pro are well made, and designed with attention to detail, but the hex bearings are awful. We have an older robot for demonstrations that has a transmission that uses a hex bearing (not on a cantilevered shaft). For 6 years and thousands of cycles in competition and at demonstrations, the original hex bearing worked. Then, we took apart the mechanism for cleaning, and we decided to try out the vex pro hex bearing. After 3 cycles of the arm, the bearing failed completely.
