Go to Post What else could you do with a t-shirt? Wait... never mind... I retract my previous statement and realized this is FIRST and we can do anything with anything. ;) - Jeremiah Johnson [more]
Unread 03-06-2013, 22:02
Team3763 Adam Team3763 Adam is offline
Lead Programmer
FRC #3763 (4H WildCards)
Team3763 Adam can only hope to improve
Re: New computer - Blue Screen Of Death! HELP PLEASE
How do I conduct step 5? And do I run Memtest86+ while on say my desktop?
Unread 03-06-2013, 22:27
Have you already completed steps 1 thru 4?
Memtest86+ is step4, so I guess the answer to my previous question is "No".
You use the CD you burned to boot the machine you want to test. It bypasses Windows and boots Linux. That allows you to test the machine's hardware without Windows getting in the way.
Once you've done steps 1 thru 3, ask for more detail if the menus are not obvious.
Unread 03-06-2013, 22:55
Lead Programmer
Alright thank you. I'll post either in the morning or sooner if I get steps 1-4 done
Unread 03-06-2013, 23:20
I am assuming you can follow directions carefully. In step4, make sure to select the "Memtest" menu item. Do *NOT* select the FreeDOS menu item... it wants to reformat your hard disk to DOS.
You do have backups of your important data, right?
Unread 03-06-2013, 23:50
Lead Programmer
There's nothing too important on the computer yet seeing that it's fairly new. We do have all discs for the software and whatnot if need be to factory reset. When do I know when it has completed one pass and when do I know if it passed or failed? This is all gibberish to me
Unread 04-06-2013, 00:30
Lead Programmer
Also, I've been reading up into this slightly, and I've read that it could be the memory mods. If that's the case, do they have to be replaced? I know we have a 500GB Hard drive and replacing that is not cheap...
Unread 04-06-2013, 00:34
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
you can get one for 60 bucks.
Unread 04-06-2013, 06:44
It will be obvious when you run the test. The screen will indicate testing progress and pass/fail. Failure message will be in red against a blue background. You can see it all the way across the room.
Name:	Memtest86 in progress_.jpg
Unread 04-06-2013, 07:00
Lead Programmer
I let it run overnight and it got to pass test8 with 9 errors, but there was only 1 on test 1 then no more errors until test 5
Unread 04-06-2013, 07:08
You want zero errors. Even one error is unacceptable.
If I were you, I'd remove the offending memory cards.
Unread 04-06-2013, 07:09
Lead Programmer
The program didn't get past test 8, but I'll rerun it.
Unread 04-06-2013, 07:13
If I were you, I'd remove the offending memory card(s) before re-running it.
How much memory is in this machine?
Unread 04-06-2013, 07:25
Lead Programmer
I believe we only have one memory card, but I don't know how to check
The hard drive is 500GB
And I know it has 16GB of useable RAM
Unread 04-06-2013, 07:43
Use your digital camera to take a picture of the Memtest86 screen, and post the picture in this thread. Make sure to use the macro setting on the camera.
Unread 04-06-2013, 07:51
Lead Programmer
Alright, I'll do so when I get home today after school. On Memtest I remember it had 16gb of useable ram and 15GB remaining unscanned.
