Go to Post Smart defense doesn't even require your robot to push another. - Cory [more]
Unread 03-06-2013, 21:31
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
WCD Bearing Blocks
I have a question regarding West Coast Drive bearing blocks.
Based on many of the pictures and CAD models I've seen, the "standard" way to create them is to cut a pocket all the way thru your 2 x 1 x 1/8 siderail, and then slide a bearing block into the pocket from the side. Once in place, the bearing block gets a plate bolted to it from both sides to hold the block captive in the slot while allowing it to slide front to back.
It seems a simpler approach would be to cut the same pocket in the siderail, but then slide a 1.75 x .75 bearing block in the siderail from the end. This would just fit inside the inside dimensions of the tube, and would eliminate the need for the sideplates and fasteners.
I can see a downside to the simpler approach, and that is that you need access to the end of the tube you're installing the block in. That doesn't seem like that big of a deal. I would think the two would be comparable from a weight standpoint. Is there another downside to this approach that I'm missing?
Unread 03-06-2013, 21:35
AdamHeard's Avatar
Lead Mentor
Re: WCD Bearing Blocks
A long, long time ago (before my time even) 973 used to do this.
The problem is the inside of extruded tube is all over the place dimensionally, so this blocks end up being really finicky.
Unread 03-06-2013, 22:43
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Also, there is some benefit to having the bearings outboard of the 1" tube. Having both bearings only 3/4" apart to the outsides seems a bit narrow.
Unread 03-06-2013, 23:26
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
Bearing blocks are probably the trickiest part to design and machine of a WCD. At this point, they've become pretty standard for various reasons. Many teams use something like this.
As Adam said, the relatively poor tolerances in tubing makes bearing blocks on the inside difficult. The tubing from McMaster-Carr has tolerances of .044" for the outside dimensions, and it's probably much worse for the inside.
One benefit of the standard method (linked above) is that you can put a CAM on the pointed ends for tensioning.
2009-2013: Student, Team 100
2013-????: ?
Unread 03-06-2013, 23:32
craigboez's Avatar
Mechanical Engineer
The only CAM tensioners I've seen appear to be very difficult to machine on a manual mill and very custom. How do you approach the tensioner?
Unread 03-06-2013, 23:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
A cam could be square. Or you could sand a radius into it. It doesn't need to be as fancy as what we make, for example. You just need something with a non-constant radius. They don't even need to all be perfectly the same since you're not going to get the exact same tension across all your chain runs.
2001-2004: Team 100
2006-Present: Team 254
Unread 04-06-2013, 00:01
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
For our chain tensioner cams we used a ~1/4" thick piece of 3/4" or 1" (I don't remember which) steel shaft with a hole close to the edge and welded a #10/32 socket head alan bolt into the hole.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 04-06-2013, 00:07
craigboez's Avatar
Mechanical Engineer
Once you rotate the cam so the chains are properly tensioned, how do you lock the cam in that position?
Unread 04-06-2013, 00:19
wilful's Avatar
We have a lock nut on the other side that is tightened down, but that is less important than tightening the bearing block together from what I've seen.
Wilful
Unread 04-06-2013, 00:34
Cory's Avatar
AKA: Cory McBride
The cam has a tapped hole in it. You just tighten it down and then tighten the bearing block.
2001-2004: Team 100
Unread 04-06-2013, 00:36
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
how often do you need to re-tighten the chains or does it typically stay in place all season after you tighten them the first time
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 04-06-2013, 01:05
wilful's Avatar
we tightened ours whenever they felt loose, which occured often after a pushing match
Wilful
Unread 04-06-2013, 01:13
Cory's Avatar
AKA: Cory McBride
The bearing blocks stay in place after properly tightening them and the cam, if that's what you're asking.
The only reason you would need to re-tension is to deal with the chain stretching slightly over time as it loosens up.
2001-2004: Team 100
Unread 04-06-2013, 02:25
craigboez's Avatar
Mechanical Engineer
Thanks for all the explanation. I never realized that the sideplates actually clamped the bearing block in place. The cam tensioners make a lot more sense now.
Unread 04-06-2013, 03:45
AKA: Andrew Blatner
Usually the side plates actually ARE the bearing blocks. The bearings are in the two side plates which fasten together from opposite sides of the tubing.
2013-????: ?
