Go to Post We were all rookies once. Some of us still are... - Wayne C. [more]
Unread 03-06-2013, 23:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: WCD Bearing Blocks
Originally Posted by craigboez View Post
The only CAM tensioners I've seen appear to be very difficult to machine on a manual mill and very custom. How do you approach the tensioner?
A cam could be square. Or you could sand a radius into it. It doesn't need to be as fancy as what we make, for example. You just need something with a non-constant radius. They don't even need to all be perfectly the same since you're not going to get the exact same tension across all your chain runs.
2001-2004: Team 100
2006-Present: Team 254
Unread 04-06-2013, 00:01
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
For our chain tensioner cams we used a ~1/4" thick piece of 3/4" or 1" (I don't remember which) steel shaft with a hole close to the edge and welded a #10/32 socket head alan bolt into the hole.
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 05-06-2013, 14:12
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
As a "customer" of 766, I can attest that these work well. We even discussed removing the cam after tensioning to save weight since the bearing blocks we use can grip the box tubing so well. The cam tensioner looks like a automotive Cam bolt. I could never find one small enough to work. I suppose this design could be improved by using an aluminum 1/4-20 bolt and a 1/4" thick piece of aluminum to save weight. I don't think the loads are high enough to wear out the aluminum bolt. Plus it is nice to have more area to weld to.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
