Go to Post Imagine the pressure on Dave Lavery - every time he sneezes someone assumes it's a game hint. - Gary Dillard [more]
Unread 04-06-2013, 15:30
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: WCD Bearing Blocks
Originally Posted by ablatner View Post
Usually the side plates actually ARE the bearing blocks. The bearings are in the two side plates which fasten together from opposite sides of the tubing.
It sounds like there are two common ways to create the bearing block assembly.
  1. Use two sideplates and a block of aluminum. The bearings go in the aluminum block, the sideplates hold it all together and clamp it in place. The machining for this setup is relatively simple.
  2. The two sideplates become the bearing block and are constrained coaxially with a short piece of thick walled tubing that connects them. The machining for this setup is comparatively complex.
Is that a fair statement? If so, what are the benefits to method #2?
Unread 04-06-2013, 18:05
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
I've never actually seen #1.
2009-2013: Student, Team 100
2013-????: ?
Unread 04-06-2013, 19:36
Nate Laverdure's Avatar
FRC #2363
The Team 221 "Universal Chassis" uses this design.
This is a neat concept along the same vein.
Unread 04-06-2013, 19:39
AdamHeard's Avatar
Lead Mentor
We run #1. CAD in sig. 09 was unique, 10 and 11 were new design.
Unread 04-06-2013, 19:55
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by Nate Laverdure View Post
The Team 221 "
Given that those already have to be CNC machined there's not a lot of benefit to doing it that way than the way we do ours.
2001-2004: Team 100
2006-Present: Team 254
Unread 04-06-2013, 21:10
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Jabba made one like this while mentoring for 931 several seasons back.
They refined the design and used it a couple of times since, I think.
Richard Wallace
since 2003
Unread 05-06-2013, 14:12
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Originally Posted by wilful View Post
For our chain tensioner cams we used a ~1/4" thick piece of 3/4" or 1" (I don't remember which) steel shaft with a hole close to the edge and welded a #10/32 socket head alan bolt into the hole.
As a "customer" of 766, I can attest that these work well. We even discussed removing the cam after tensioning to save weight since the bearing blocks we use can grip the box tubing so well. The cam tensioner looks like a automotive Cam bolt. I could never find one small enough to work. I suppose this design could be improved by using an aluminum 1/4-20 bolt and a 1/4" thick piece of aluminum to save weight. I don't think the loads are high enough to wear out the aluminum bolt. Plus it is nice to have more area to weld to.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 05-06-2013, 20:58
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I like these a lot.
If you created the center block with a single through hole and made the side plates with a larger hole in them to accommodate for the flange then you could make these without flipping the stock.
And if you have a drill bit at 1.125 and 1.25, you could do it without CNC work.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 05-06-2013, 22:50
FRC #1836 (MilkenKnights)
The biggest benefit to #2 is weight. We've gone both routes(2012 #1 using sponsors because we didn't have a mill in house, 2013 #2 buying from WCP). If you have a CNC #2 is fine, but it isn't necessary by any means. You can do #1 super simply. When we did it, we didn't even do chamfers on the center block and our sideplates could have been made with a chopsaw. Depending on your teams resources you can make the blocks marginally more complex(chamfering the blocks means you don't have to file as much later, waterjetting sideplates is a small weight savings and they look a bit nicer). Either way works, and the method you choose completely depends on your team and its resources.
