#12
Re: JVN's Calculator (help)
@T^2: So bottom line, if I read you correctly, to get the efficiency numbers you measured the vehicle top speed in each gear, and divided that by the calculated vehicle speed at CIM-free-speed. That's an interesting method. It also helps explain why you got a higher efficiency with more gears. @all: What "efficiency" metrics and test methods do other teams use? |
