Go to Post Most of the people who fit the profile of long tenured FIRST mentor are either already on a team or locked up in an institution where they belong... - PayneTrain [more]
Unread 07-06-2013, 09:20
Gdeaver Gdeaver is offline
FRC #1640
Re: Favorite Sensors
For a 360 degree no dead band angular position sensor, I like the cost and performance of the TT Optek 6127V1a360L.5FS. It has worked very well for our swerve steering position sensing. For a quadrature encoder we are looking at the CUI AMT102-V. You can set the CPR by dip switches. So one unit can give 32 to 1024 CPR. We made a mount for it out of PVC with 2 ball bearings and a 1/4" shaft. For a tach the Melexis US2882 Hall effect bipolar latching switch has worked well for many teams. We are exploring the use of a Invensense MPU-6050 3 axis gyro and accelerometer this summer. One of the most stable gyro's that is affordable I have looked at yet.
Unread 14-08-2013, 13:25
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
For end of travel, home, or just sensing something moving in and out of position a vane or slot sensor works nice.
http://www.digikey.com/product-searc...819z&x=10&y=13
See attached photo for application.
-Hugh
Unread 14-08-2013, 15:33
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
I've been taken by the USDigital H-5 series of shaft encoders.
http://www.usdigital.com/products/en...otary/shaft/H5
I started using them several years ago, when I couldn't get the Greyhill ones fast enough (EVERYONE was out of stock at the time, Mouser, Digikey, Newark).
Turns out, I like them better than the Greyhill 63R because....
1) 10K RPM versus 5K. (our shooter motors ran over 6K RPM)
2) Locking, captured signal cable, doesn't fall out, nor likely to break off the header pins.
3) Discount for FRC Teams.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 14-08-2013, 19:21
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
My team (actually just myself) has been reluctant to buy any non-analog sensors other than the encoders supplied by AndyMark because we don't know if we'll be capable of writing our own classes. The encoder you linked looks stellar. Was it much of a pain to program (or could you use the classes supplied in WPILIB)? My personal favourite sensor is the USDigital MA3 Absolute Magnetic Shaft Encoder (analog option!). I wish we could get a Celesco Linear Potentiometer, but they apparently don't have a distributor in our area (Montana) and won't mail us one :/ I have no idea what for, but I'm sure we could think of something
Unread 15-08-2013, 11:26
Phalanx's Avatar
They work just fine using the standard WPILIB encoder methods. Nothing special is required.
Unread 15-08-2013, 13:33
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
For a 1-turn pot, I always use a Bourns 6639 Series Potentiometer.
They're pretty cheap, and they're continuous so you won't destroy them if you drive them past their extents.
I will never use a fixed 1-turn pot ever again.
We've had success with LV-MaxSonar-EZ Ultrasonic Rangefinders as well. They're easy to work with, and give reliable reads in the right conditions with a simple median filter.
When it comes to optical sensors, Banner's WorldBeam QS18 Series have never let me down. We like to use a visible light one, so we know whether the sensor is working, and what it's pointing at. They've held up in high-speed applications too, as we used one of these to measure our shooter speed by colouring parts of it black and white.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 16-08-2013, 13:59
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
My favorite sensor, hands down, is the lowly limit switch. You can do just about anything with these things. That and they are cheap, tough, little buggers.
My second favorite is a broken beam sensor. I don't know the make or model of the ones that we use. They are easy to install as well as easy to program. They also glow red in the dark, which you know, is kinda important
You have to be careful with the broken beam sensors, however. If you order some, make sure they use LEDs for the light rather than a laser. Also, you get improved reliability if they are in an environment where they are not exposed to too much direct light.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 17-08-2013, 02:55
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Thanks for this, I had been looking for something like this for a while.
