Go to Post I was not looking at this as a backdoor to asking Brandon to do it (when I have impossible/unreasonable tasks I want done, I ask him straight out ;-) - Joe Johnson [more]
Unread 29-05-2013, 08:19
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Best way to learn LabView for FRC?
I'm interested in learning Labview to at least assist our main programmer next year. We only have one, so the more, the better. I know rudimentary things with regards to labview, and I've taken a few programming classes using other languages, so I have a basis of knowledge. What would be the best way to expand my Labview skills, specifically with regards to FRC? Are there books or websites on the subject?
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 29-05-2013, 09:08
Re: Best way to learn LabView for FRC?
There are lots of materials here ... https://decibel.ni.com/content/docs/DOC-8923
And though it is a bit dated, frcmastery.com is good if you mostly want to watch videos.
The way I personally get people up to speed in LV is to get them to reprogram a project they recently completed. Say, something from a senior design class. That way they know the problem well, they are familiar with some milestones in the solution, and are mostly learning the tool. If you have a similar app that is strictly PC based, it allows you to do it on just a laptop.
The next step would be to program the robot in the simulator, then on the robot itself.
Greg McKaskle
Unread 07-06-2013, 06:22
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
i always recommend http://team358.org/files/programming/ControlSystem2009-/LabVIEW/ for learning labview. It has many different examples of robot code for practically every task that would need to be programmed.
Note: only useful after you understand the workings of labview
Unread 08-06-2013, 15:54
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
See Signature Below.
Unread 08-06-2013, 16:03
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
The best way to learn is to fail. Aka, experiment.
Also, http://team358.org/files/programming...2009-/LabVIEW/ that was posted above, was a great resource for me when I was learning Labview (halfway through a season!). Try mixing some of their examples together and like I said, experiment.
Make a testbed with a basic control system, with a few different kinds of motors, relays, and sensors, so you can test out your code.
Good luck
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 08-06-2013, 16:29
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
I know NI has a good LabVIEW YouTube channel with a pretty good intro into LabVIEW itself. This coupled with FRC Mastery and general experimentation is what I used to learn the language. Also, learning to use the little shortcuts (e.g. probing wires) that are available in LabVIEW and not other languages helps to debug your code and to increase your skill in quickly identifying where a problem is occurring.
Source: 2.5 years of heavy FRC LabVIEW development and serving as the go-to programmer for other teams at quite a few regionals.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
