Thread Tools |
Rating:
Display Modes |
Re: Swerve Drive Concept
I could, but then I would have to move the side plates in a little bit, or make the tabs thinner than the side plates. Also, I don't really know how those right angles could be machined easily.
You won't be able to machine the female slots the way they are in the picture (at least not with conventional subtractive manufacturing). What you could do though is do a pair of slots oriented orthogonal to each other (one provides constraint in the Z axis, the other provides constraint in the Y axis, and the screw/surface provide constraint in the X axis). As for the male bosses, you'd clamp the piece in the vice so that the bosses would be sticking straight up, and mill across the top. Not very nice if you've got a long piece (or you'll want to use a horizontal mill). That tab design is generally reserved for plastics cut on a laser cutter.
As long as there are still flats on each side of the boss and hole, there won't be a change in effectiveness. In fact, having the radii in the corners will increase the strength of both parts. (Sharp corners provide a convenient fracture point for the material) |
Do you plan on making or buying the bevel gears? They would probably wind up being one of the most machining intensive pieces in this design.
The miter gears are from http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=l110y&op=search&Ntt=l110y &N=0&GlobalSearch=true&sst=subset
#7
The process of cutting good gears is not a simple one, and it requires some pretty specific equipment, very few professional machine shops even have that kind of stuff. Last edited by CENTURION : 12-06-2013 at 02:51. |
#8
:Bevel Gear Tube Drive I was asked to cut these high quality bevel gears, for the exact purpose to show that with today's machining capabilities, you don't have to be a gear manufacturer to produce high quality bevel gears. Several of these displays are travelling to Trade-shows and Expos, to highlight the capabilities of the OMAX Waterjet's: "A-Jet" A-Jet Demonstration Video I <3 my job ![]() |
#9
What would it take to get access to one of these fine machines ![]() |
#11
Though I'd classify a five-axis waterjet as "specialized equipment", that most shops don't have. You could do a similar cut with a four-axis mill and some fancy cutters too, but a lot of shops don't have those either. |
#12
![]() Quote:
*Not sure of exact $ |
