Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 08-06-2013, 17:28
magnets's Avatar
magnets magnets is offline
Swerve Drive Concept
Here is a swerve drive concept that I've been working on. Any suggestions/feedback is welcome. Not shown is a steering encoder and a schedule 80 PVC pipe that goes around the swerve module. The module has a disc connected to the side plates that has a delrin ring to provide another bearing for the module's rotation.
Last edited by GaryVoshol : 08-06-2013 at 20:10. Reason: removed "if this is duplicate" message
Unread 08-06-2013, 21:16
Re: Swerve Drive Concept
Question: Is this meant to also be the power unit for the entire drive? Or is one of those motors a Mini-CIM? (Or, is this for a 3-wheeled swerve?)
Unread 08-06-2013, 22:54
magnets's Avatar
It can be a three wheel swerve, or it can be a four wheel swerve with a minicim.
Unread 08-06-2013, 22:56
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
8 motor drive, I love it.
What is the steering motor?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 09-06-2013, 01:25
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Design looks pretty good. I dig the 8 motor design.
The top orange plate on the module seems overly complicated, from a machining standpoint.
Instead of having those little flanges hanging down, why not just bolt downwards through the orange plate into the two side plates?
What are you using to rotate the module?
And how are you tensioning the chain? It's hard to see what's going on back there.
I sort of consider 1640 to be the gold standard of swerve (Well, tied with 1717 maybe ), and they've really taken the time to iterate, improve their design, and cut out unnecessary things. They also released everything you could want to know online. I'm not saying ditch your design and go with theirs, but they've already solved a lot of the problems for you, so you can learn from their mistakes so to speak
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 09-06-2013, 02:15
DampRobot's Avatar
Physics Major
AKA: Roger Romani
If you look at the first photo, you can see a second chain run going up to a motor hidden behind the top plate and the two CIMs. From the little I can see, I'd hazard a guess that it's a 550 with a BaneBots planetary.
-Plutarch
Unread 09-06-2013, 09:48
magnets's Avatar
You're right, to make the orange plate would waste a lot of material, so I think the little tabs could be replaced with a steel bracket, and then I could put a could more bolts straight down through the orange plate and into the blue side plate, like you described.
To keep the chains tight, we plan on putting spacers underneath one side of the lower gearbox plate until the chain is tight. We've done this in the past, and we only had to adjust the shims twice during the season to keep up with the stretching chain. The chain for the swerve module has a calculated center to center distance, and its small enough that it doesn't need tensioning.
Unread 09-06-2013, 13:38
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
You could use this type of joint.
Unread 09-06-2013, 14:01
magnets's Avatar
I could, but then I would have to move the side plates in a little bit, or make the tabs thinner than the side plates. Also, I don't really know how those right angles could be machined easily.
Unread 10-06-2013, 15:54
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
You won't be able to machine the female slots the way they are in the picture (at least not with conventional subtractive manufacturing). What you could do though is do a pair of slots oriented orthogonal to each other (one provides constraint in the Z axis, the other provides constraint in the Y axis, and the screw/surface provide constraint in the X axis). As for the male bosses, you'd clamp the piece in the vice so that the bosses would be sticking straight up, and mill across the top. Not very nice if you've got a long piece (or you'll want to use a horizontal mill). That tab design is generally reserved for plastics cut on a laser cutter.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 11-06-2013, 16:24
CENTURION's Avatar
I assume you're replying to this post:
You're right, those sorts of joins are generally used in laser cut parts. However it can be done with normal machining, the design just needs to be modified a little. Your cutter will leave a radius in the corners of the female slots, so just add a matching radius to each corner of the male boss.
As long as there are still flats on each side of the boss and hole, there won't be a change in effectiveness. In fact, having the radii in the corners will increase the strength of both parts. (Sharp corners provide a convenient fracture point for the material)
Unread 11-06-2013, 17:48
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
Do you plan on making or buying the bevel gears? They would probably wind up being one of the most machining intensive pieces in this design.
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
Unread 11-06-2013, 18:41
magnets's Avatar
The miter gears are from http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=l110y&op=search&Ntt=l110y &N=0&GlobalSearch=true&sst=subset
Unread 12-06-2013, 02:49
CENTURION's Avatar
I don't think I've ever seen anybody make bevel gears besides gear manufacturers
The process of cutting good gears is not a simple one, and it requires some pretty specific equipment, very few professional machine shops even have that kind of stuff.
Unread 13-06-2013, 01:01
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Well then, check my video out :
Bevel Gear Tube Drive
I was asked to cut these high quality bevel gears, for the exact purpose to show that with today's machining capabilities, you don't have to be a gear manufacturer to produce high quality bevel gears.
Several of these displays are travelling to Trade-shows and Expos, to highlight the capabilities of the OMAX Waterjet's:
"A-Jet"
A-Jet Demonstration Video
I <3 my job
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
