Go to Post When twenty people tell you your hair is on fire, you don't need to look into a mirror to find out they're right. - IndySam [more]
Unread 07-06-2013, 13:30
DanUeda DanUeda is offline
FRC #0321 (RoboLancers)
DanUeda is an unknown quantity at this point
Question Robotics Workspace Floorplan
Team 321 is looking to move into a new workspace after next year and are looking for some guidance. We are renovating a large storage area big enough to have a sizable shop, storage, and half a field. The problem is I don't know where to turn for guidelines about creating a good shop. If anyone has resources they could point me to or if you have blueprints to your own shop, I would greatly appreciate it.
Thanks!
Unread 07-06-2013, 14:15
Re: Robotics Workspace Floorplan
Thanks!
Hey Dan,
Check in with 1640. 987 also has fantastic pictures of their workshop posted up on facebook.
https://www.facebook.com/pages/High-...hotos_strea m
Hope 321 has fun with a new build space!
Unread 07-06-2013, 14:33
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Congrats on getting a new shop space!
For the Break Away season, we moved into a new shop space (A loft in downtown St. Paul) that had been completely renovated for us. We kept the layout big and open for the shop area, but had a section area for programming, PR, and meals walled off with windows into the shop area (the windows help the team feel like a whole team, instead of breaking off into subgroups that never see each other). There was a dedicated space for storage (We found some Home Depot-style shelving real cheap on Craig's List). We kept the machining tools in one area, with final assembly in another, 5 or so feet away - you want to be able to provide supervision over the tool usage easily.
After the season was over this year, we got to move into our brand new build space in the school. This we literally got to design from scratch - it was an addition to the school, not a remodel.
In designing this space, there was a lot we wanted to consider:
1. Noise: The machine tools can be loud. We wanted the "Machine Shop" separated from the assembly area, so we could close the doors to keep noise down.
2. Power: We wanted to make sure we had sufficient power for our needs, while maintaining safety. This resulted in a master safety switch in the shop that, when pressed, cuts power to every machine in the room. This way we don't have to run past people or dart in near a machine if we see something unsafe happening. We also made sure we had outlets spaced/located where we wanted them, according to our floor plan. If that wasn't enough, we have power drops in the ceiling as well - they're dangling from spring-loaded lockable reels, so the outlet can be stored above head height, but when pulled out can reach all the way to the floor
3. dust collection: When using machine tools, a lot of dust is generated. In the end, we ended up without a built-in dust collection system due to complexity and the need to support both wood and metal. Instead, we're still using the shop-vac for dust collection.
4. compressed air: We designed in an exterior compressor that has a line running into the build space. This way we have the benefits of compressed air, without the loud compressor in the room
5. Tall ceilings: Our old build space had 11 foot ceilings, which isn't really quite tall enough. The new one has massive ceilings that I hope we'll never have a need to hit
6. Loading bay: We have an insulated garage door in the assembly room. This lets us back the trailer fully into the room for loading/unloading, which is really great in Feb/Mar! It also gives us as much room as we need to load stuff in and out of the area.
7. Carpet on the practice area! Our practice area is a little bigger than a half-field sized room, carpeted, which doubles as a classroom. All of the desks/chairs are on wheels, which makes it pretty quick to clear out the room for driver practice
8. Extra rooms: We have a dedicated conference room with a table, seats for 12, 3 white boards, and a large screen TV we can hook the laptops up to. We also have a dedicated Lego League room with adjustable height tables and room for several groups to work.
For spacing on equipment, use common sense or look for guidance from the manufacturer. Space things out far enough that you won't be bumping elbows, and so your parts can fit (for example, you'll often use a band saw to cut through 12 foot long square tubing) without too much hassle. Leave room to walk, so people can walk behind others that are using the tools.
2016: Lake Superior WFFA
Unread 09-06-2013, 12:19
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
We have run out past three build seasons in three different warehouses. This has worked out very well for us, and we've had the opportunity to learn a bit about shop organization in the process.
Space division - we organize our space around function, with some flexibility and reallocation as build season progresses. The key space / function allocations are:
  1. "Quiet" space for programmers, CAD, classes - "Quiet" can be a relative term, but we always have sitting-down, table and chair work space for these groups (and others). Usually some distance from the band saws (if not in a separate room). CAD folks generally don't want to be too far from the action.
  2. Storage space - There are really three different kinds: a) organized semi-permanent storage for generic parts, documents, etc; b) a little less organized maybe for aluminum, polymer and wood stocks; and c) dynamic storage for subassemblies and parts for ongoing robot construction or testing. We use shelves with labeled plastic totes (of varying size) for a; racks & buckets for b; and rolling steel wire carts for c.
  3. Machine space - for mills, lathe and other precision fabrication
  4. Welding space - needs some isolation from the rest of the shop to protect bystander eyes and keep flammable materials away. Also a good space for laying up composite materials, but only if there is no welding in progress.
  5. General workshop & Assembly - Band-saws and drill presses are here, along with work benches, arbor presses, vises, most tools, etc. Also used for laying up composite materials (or welding areas used for this if welding is not in progress). Most of the mechanical students will spend most of their time here.
  6. Practice Field - tends to grow as the season progresses. Needs a realistic surface (generally carpet which you can damage without serious consequence if it comes to this). A permanent practice field is a great tool for driver training & tactics development.
  7. Restroom(s) (need I say more?)
  8. Kitchen (very nice to have)
Actual location and size of these areas depend upon your space and your fabrication suite.
Power:
Our mill and MIG welder require 220 VAC (3 & 1 phase, respectively). Since it is expensive to run this service long distances, Our Machining and Welding spaces tend to be located close to the source and therefore also close to each other. These power services require professional installation.
Everything else runs off 110 VAC. In large, open area, these services tend to be located along walls. Try to organize users as well as possible to avoid excessive use of long extension cords (and then tell me how you managed to do this).
Heat:
As a Pennsylvanian, I come down firmly pro-heat, especially during January/February build season. But heating a large open commercial space can be very expensive and we've had to pay for building utilities during our last two years. So our heat is definitely been minimalistic during this period. No problem if someone else is paying, but if you are, then I'd have folks bundle up for robotics.
Access:
During build season, having 24/7 access to your workshop is just golden. Important to decide who has access (who can open the building). Beyond this, a drive-in door and/or a loading dock are very, very useful.
Internet Access:
Essential. We've been using MiFi, but this is limited.
I'll post some links to shop photos in a follow-up message.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 09-06-2013, 12:32
Clem1640's Avatar
Head Mentor
AKA: Clem McKown
Programming area (a-storage in background):
http://wiki.team1640.com/index.php?t..._130109-15.jpg
http://wiki.team1640.com/index.php?t...209_csm-13.jpg
Isolated welding area:
http://wiki.team1640.com/index.php?t...0208_csm-7.jpg
http://wiki.team1640.com/index.php?t...0209_csm-6.jpg
Clem McKown
Unread 09-06-2013, 12:44
Clem1640's Avatar
Head Mentor
AKA: Clem McKown
Practice field:
http://wiki.team1640.com/index.php?t...218_csm-20.jpg
http://wiki.team1640.com/index.php?t...0221_csm-1.jpg
Storage:
http://wiki.team1640.com/index.php?t...p_Organization
http://wiki.team1640.com/index.php?t...204_csm-13.jpg
Clem McKown
Unread 10-06-2013, 15:48
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
One thing I might add is to also set up a dedicated electronics bench (soldering station, power supply, etc). You want to keep electronics away from the machining areas so that you don't get dust and other junk between the pins (thus shorting out your entire system), and there's really not much overlap in terms of tools for the electronics guys and the mechanical guys. The electronics bench can also double as a test bench, where you can basically have a clear area to test systems in, with access to the tools you'll most likely need to do quick fixes during testing (you generally don't need a machine to quickly fix something during testing - if you need that, it's not a "quick fix" anymore).
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 10-06-2013, 18:09
Consider a "lounge" area where students can do homework without getting in the way of other team members, and an "office" area where mentors can gather to discuss things that students shouldn't have to worry about. Don't forget to plan for a trophy case and/or a place to hang banners. A prominent bulletin board and place for a calendar would probably be a good idea.
Will you have a shop telephone? If so, make sure you can put it somewhere that won't be too noisy.
Unread 11-06-2013, 13:10
These are great recommendations everyone! Thank you. I might even collect all these into a document for future use. Please keep them coming.
Does anyone have knowledge of a shop design guide or a description of machine envelopes?
Thanks!
Dan
Unread 11-06-2013, 14:03
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
One of the mentors and hard working students' pet peaves is other students coming to robotics to do their homework. Homework is meant for working on at home, not while the mentors are staying late at robotics to help build the robot. The mentors are there to work on the robot, not to be baby sitters for students.
I wish our government had this much money like yours, to spend on schools like this for your great education systems. Oh wait...
I definitely like having designated areas for assembly, machining, electrical wiring, programming, practice and other stuff. These suggestions are great and i wish my team had that oppurtunity to customize shops like that.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 11-06-2013, 18:49
Clem1640's Avatar
Head Mentor
AKA: Clem McKown
Thanks!
Dan
We've got machine envelopes, but these turn out to be pretty machine specific. It's best to develop these based on your own team's machines.
Clem McKown
Unread 11-06-2013, 19:00
The machine envelope is, in practice, the area that the machine operator needs to run the machine. That includes any area that the machine can extend parts into (like the table on a mill or the handles on a lathe, or the operator panel on a CNC) as well as enough room for the operator and a tool area if needed.
If you can, mark the floor around each machine with its envelope--if you're in the marked envelope, and you're NOT the operator or mentoring/assisting the operator, you should probably find another place to be!
The homework area suggestion is actually a good one, and here's why: If the students have some things that can be done at home, but won't take a lot of time, or if there's time before the start of the meeting, crash there for a few minutes and do the homework, then jump right into the build. (Also great as a quick break.) If done right, with tables and chairs, you also get a food area for those late-night or all-day build sessions.
Unread 11-06-2013, 21:51
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
We use extruded aluminium (8020?) walls and doors to surround machines that aren't in are machine shop.
The doors have safety interlocks on them to prevent the machines being turned on without the proper procedures being completed.
http://www.tdsb.on.ca/schools/ShowIm...atureID=222315 (I apologize for the obnoxious picture. It is the only one I could find)
2016: FRC 865 Mentor
Unread 11-06-2013, 22:14
I'm pretty sure that's just safety guarding fences (don't know the real name). Most, if not all, companies that make robots have to have those around them so no humans can get inside the area. Yours might just be normal extrusion painted yellow though.
and those look like normal robots used for assembly lines or welding, they don't look like normal machines, are they?
2013-Present
2010-2013
Unread 11-06-2013, 22:35
mman1506's Avatar
no team (WARP7)
The extrusion has a T-slot profile very similar to 80-20. They were installed with the arms so they are likely sold by a safety guarding company. You could probably do the same thing with any T-slot extrusion.
They are Motoman HP6 robotic arms equipped with a resistance spot welder. The arm's head position is programmed using normal Cartesian coordinates (X,Y,Z) just like any other CNC machine. We also have the cage installed around our plasma cutter.
