Go to Post Wow, what a regional at St. Louis! ... It's gonna be a good year for FIRST. - Andy Baker [more]
Unread 12-06-2013, 13:10
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Use Sidecar I2C port to communicate with Arduino?
My team is working on a project that involves the digital sidecar sending information over I2C to an Arduino Uno (R2, if it matters). Is this possible, and how can it be done? I know nothing of LabView (which is what my team uses to program the robot) but I know quite a bit of arduino C.
Would this code work? All I need to do is have the Arduino receive one byte of information at a time. I want the Arduino configured as master and the sidecar configured as slave.
#include <Wire.h>//I2C library for Arduino
int d = 999;     //arbitrary int used for state change stuff
void setup() {
  Wire.begin();                  // join i2c bus (address optional for master)
  delay(1000);
void loop() {
  Wire.requestFrom(1, 1); //Request data from slave device (the sidecar)
    while(Wire.available()) {
    int dat = Wire.read();
    if (dat == 0) {
           if (d != 0) {
             //runs once every time state changes to 0
           d = 0;
             //runs repeatedly while state is 0
     if (dat == 1) {
           if (d != 1) {
           //runs once every time state changes to 1
           d = 1;
     //runs repeatedly while state is 1
     if (dat == 2) {
           if (d != 2) {
           //runs once every time state changes to 2
           d = 2;
     //runs repeatedly while state is 2
     if (dat == 3) {
           if (d != 3) {
           d = 3;
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 12-06-2013, 13:32
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: Use Sidecar I2C port to communicate with Arduino?
evanperryg,
You can use the cRIO to communicate with the Arduino, several teams have done so, including mine. However, to the best of my knowledge, the cRIO has to be the master as an I2C slave is not currently supported. There are a couple of threads on this topic that might help if you search. I can help if you have specific questions from the Arduino side, (or cRIO from a Java perspective).
Mike
Unread 12-06-2013, 14:58
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Our team has been having some trouble with this. We don't have anybody experienced with the arduino, and we are seeing what we think to be incorrect I2C timing on the cRIO side. If you have an example for the arduino and for java, it would be appreciated.
Unread 12-06-2013, 16:17
FRC #1126 (& 1511)
I will try to post some sample code tonight, however if you are having what you believe are timing issues, take a look at this post.
Mike
Unread 12-06-2013, 18:17
evanperryg's Avatar
AKA: Evan Grove
I've done some research, and I have pretty much drawn a blank on how to get this to work. If someone has example code of an arduino being used as slave and recieving data, then that would be awesome.
2013
2015
Unread 12-06-2013, 18:56
armgeek's Avatar
armgeek armgeek is offline
Raspberry Pi Enthusiast
AKA: Tyler Pawlaczyk
FRC #0340 (Greater Rochester Robotics)
armgeek is an unknown quantity at this point
Did some quick googling, found this that should work for i2c on the arduino side.
#include <Wire.h>
void setup()
  Wire.begin(2);                // join i2c bus with address #2
  Wire.onRequest(requestEvent); // register event
  Serial.begin(9600);           // start serial for output
void loop()
  delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void requestEvent()
  static char c = '0';
  Wire.send(c++);
  if (c > 'z')
    c = '0';
Also, the i2c libraries for the cRIO only support master mode... With good reason. Conceptually, the cRIO is the master of all of the networks onboard the robot, because it collects data and uses it to move the robot.
I enjoy ARM processors.
Looking to earn rewards for working on Open-Source projects that help FIRST? You may be interested in the Summer of FIRST 2013 project. More info: 2013.summeroffirst.org
Also, visit my (sparse) blog: rainingbitsandbytes.blogspot.com
Unread 12-06-2013, 19:14
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
We used an Arduino on our robot, this year, to give us very accurate gyro readings and to control LED's on the robot. We program in java on the cRIO and at first had trouble. It turns out that the cRIO is not defaulted to transfer I2C data correctly because we would receive fault values followed by a correct value. To fix this issue we added the line:
private static I2C i2c = digitalSidecar.getI2C(4);
i2c.setCompatabilityMode(true);
to our startup code.
This solved our main problem and data was reliable recieved/sent after that,
WHAT TIME IS IT?
1126
Unread 12-06-2013, 19:51
stingray27's Avatar
stingray27 stingray27 is offline
AKA: Michael Ray
FRC #0027 (Team RUSH)
stingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to all
Here is some sample code from http://blog.oscarliang.net/raspberry...connected-i2c/ that communicates via I2C to a Raspberry Pi, although it will be pretty much the same to communicate with the cRio.
#include <Wire.h>
#define SLAVE_ADDRESS 0x04
int number = 0;
int state = 0;
void setup() {
    pinMode(13, OUTPUT);
    // initialize i2c as slave
    Wire.begin(SLAVE_ADDRESS);
    // define callbacks for i2c communication
    Wire.onReceive(receiveData);
    Wire.onRequest(sendData);
    Serial.println("Ready!");
void loop() {
    delay(100);
// callback for received data
void receiveData(int byteCount){
        number = Wire.read();
        Serial.print("data received: ");
        Serial.println(number);
        if (number == 1){
            if (state == 0){
                digitalWrite(13, HIGH); // set the LED on
                state = 1;
            else{
                digitalWrite(13, LOW); // set the LED off
                state = 0;
// callback for sending data
void sendData(){
    Wire.write(number);
Michael Ray
Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 16-7-0 Best Finish: Winner (Kettering Invitationa)l
Unread 12-06-2013, 22:03
FRC #1126 (& 1511)
OK, here is some sample code that should allow you to communicate between an Arduino and the cRIO. Sorry for it being a little longer than I intended. First off, while the format is similar to what we use on the robot, I can not test this out to ensure there are no errors as I do not have the hardware available. There shouldn't be any syntax errors, but by extracting and making a sample program, I may have introduced some other problem. Hopefully not so severe that you can't make it work relatively easily.
This sample includes both a read and a write example with the Arduino code handling both. A couple of items to note... A write/read transaction is never performed in the same function call. This is because there is a bug in the Arduino wire library that sends a "STOP" after the first part of the transaction even though it is setup as a SLAVE. There is a fix for this, but I have not had the chance to test it out. This method of splitting the write and read into two parts should always work. Second, there is a bug in the JAVA version of the I2C library that could corrupt data sent to the Arduino if any of the bytes are greater than 127. This is due to how the library combines the "bytes" into "int"s prior to sending and JAVA interprets all bytes as signed. The next version of WPILib will correct this. 'C' and Labview users shouldn't see this problem. Finally, the Arduino code uses an I2C address of 2, while the cRIO uses an address of 4. This is intentional.
The cRIO code is not complete. It only has pieces that can be added into your own code and prints out error messages if the communication fails. The Arduino code, however, is a complete sketch and "should" work out of the box. Finally, you need to have at least 3 wires between the cRIO and the Arduino for the Clock, Data, and Ground. Omitting a ground wire between the two will cause the communication to fail.
If you have (find) any errors, let me know and I will try to fix them. Hope this helps.
Mike
cRIO Part
import edu.wpi.first.wpilibj.I2C;
public static byte dataReceived[] = {0, 0, 0, 0, 0, 0, 0};
private static byte dataToSend[] = {0, 0, 0, 0, 0, 0, 0};
// In the constructor, add the following line.  This puts the i2c device into
//   CompatibilityMode, this ensures compliance with the entire i2c spec
// This routine retrieves the incrementing counter value from the Arduino and reconstitutes
// it back into a 32 bit integer.  This is a rather convoluted way of doing it as JAVA does
// not support an unsigned single byte (bytes are signed)
public int arduino_counter()
  // Request Command #1 - Return Counter Value ("Register" 1)
  i2c.write(1, 0);
  // Read 5 bytes of data, with 0 bytes to send.  A false return value indicates success
  if (i2c.transaction(dataToSend, 0, dataReceived, 5) == false)
    // If the data returned is indeed the counter, the first byte should be a 1 - identical
    // to the value we sent above
    if (dataReceived[0] != 1)
      System.out.println("Invalid data returned from Arduino - command 1");
    else
      return (((int) dataReceived[4] * 16777216) +
        (((int) dataReceived[3] & 0x000000ff) * 65536) +
        (((int) dataReceived[2] & 0x000000ff) * 256) +
        ((int) dataReceived[1] & 0x000000ff));
  else
    System.out.println("Failure to read from Arduino - command 1");
  return 0;
// This routine sends up to 6 bytes to place in the Arduino's "read/write" array and
// then reads it back into the public byte array "dataReceived" for verification
public void arduino_write(byte newData[], byte length)
  int i;
  // Maximum 6 bytes to send in addition to the "command" byte.  Place all the data into
  // the byte array.
  if (length > 6)
    length = 6;
  dataToSend[0] = 2;
  for (i=0; i<length; i++)
    dataToSend[i+1] = newData[i];
  // Send the data to the Arduino.  Do not request any return bytes or this function
  // will fail
  if (i2c.transaction(dataToSend, length + 1, dataReceived, 0) == false)
    // After successfully sending the data, perform a data read.  Since the last
    // transaction was a write with a "Command" value of 2, the Arduino will assume
    // this is the data to return.
    if (i2c.transaction(dataToSend, 0, dataReceived, 7) == false)
      if (dataReceived[0] != 2)
        System.out.println("Invalid data returned from Arduino - command 2");
    else
      System.out.println("Failure to read from Arduino - command 2");
  else
    System.out.println("Failure to send data to Arduino");
Arduino Sketch
#include <Wire.h>
byte dataToSend = 0;
unsigned long counter = 0;
byte data2[6] = {11, 12, 13, 14, 15, 16};
void setup()
  Wire.begin(2);                                            // Start I2C interface (address 2)
  Wire.onReceive(i2cReceive);                               // Receive ISR routine
  Wire.onRequest(i2cRequest);                               // Request (send) ISR routine
void loop()
  delay(10);                                                // 10 milliseond delay
  // Increment a counter every loop.  Since the ISR may interrupt this code at any time,
  // we need to disable interrupts during the increment operation so the ISR can't a
  // partially updated value.
  noInterrupts();
  counter++;
  interrupts();
// This routine is called by the ISR once a complete transmission is received from the master
void i2cReceive(int count)
  byte i2cCount;                                            // Loop/Array counter
  byte tmp;                                                 // temporary byte holder
  byte i2cDataR[7];                                         // 7 Bytes in length as that is the
                                                            // maximum that can be sent by the
                                                            // cRIO
  for (i2cCount = 0; i2cCount < count; i2cCount++)          // Read data into local buffer
  {                                                         // looping through the entire message
    tmp = Wire.read();
    if (i2cCount < 7)                                       // If more than 7 bytes in length,
      i2cDataR[i2cCount] = tmp;                             // discard remaining data as somthing
  }                                                         // is wrong.
  // the first byte read is typically what is called the register to be read/written.  This
  // example utilizes it as a "command" either to be executed or the type of data to be returned
  // when a "request" is received.
  switch (i2cDataR[0])                                      // Perform action based on command
    // Command 1: Return the counter value when the "request" occurs
    case 1:
      dataToSend = 1;                                       // Set a "global" variable for use by
      break;                                                // the i2cRequest routine
    // Command 2: Update data 2 array with what ever data is sent (if any) and allow this data
    //            to be returned to the master if it is requested
    case 2:
      dataToSend = 2;                                       // Communication for i2cRequest
      if (i2cCount > 1)                                     // More than just the command byte
        memcpy(&data2[0], &i2cDataR[1], i2cCount < 7 ?      // Limit the data to copy to 6 max
          i2cCount - 1 : 6);                                // so as to not overflow the array
// This routine is called when the master requests the slave send data.  A full transaction
// typically includes a Receive envent (register to send) followed by a Request event where the
// slave data is actually transmitted to the master.
void i2cRequest()
  byte i2cDataW[7];
  byte length;
  // I use the first byte of the data array to send a comfirmation of the information that follows.
  // This allows the cRIO a way to check what "message" is being sent from the Arduino and interpret
  // it correctly.  While this does limit the actual data part of the message to 6 bytes, the extra
  // verification, I feel, is worth it.
  switch (dataToSend)                                        // variable set in the i2cReceive event
    // Return the value of the counter
    case 1:
      i2cDataW[0] = 1;
      memcpy(&i2cDataW[1], &counter, 4);
      length = 5;
      break;
    // Return the contents of the cRIO read/write array
    case 2:
      i2cDataW[0] = 2;
      memcpy(&i2cDataW[1], &data2[0], 6);
      length = 7;
      break;
    // Unknown or invalid command.  Send an error byte back
    default:
      i2cDataW[0] = 0xFF;
      length = 1;
  Wire.write((uint8_t *) &i2cDataW[0], length);
Unread 13-06-2013, 12:58
evanperryg's Avatar
AKA: Evan Grove
Thanks guys! I will post my changed code here as soon as I can. Just in case any of you are curious, the objective of this was to add more lights to my team's robot before IRI. (and if any of you have seen our robot, you probably know we like lights. a lot.)
2013
2015
Unread 13-06-2013, 13:17
evanperryg's Avatar
AKA: Evan Grove
Thanks to you all, I got the code fixed up. If you guys see any issues in the code, please tell me so I can get them patched up as soon as possible.
/*REALLY COOL LIGHTS PROGRAM I2C rev 1.3
Evan Grove, Team 2338
released 6/13/2013
rev 0.0: 6/5/2013
This code is used for visual effects on the curved part of the shooter.
During autonomous, LEDs light up in a random pattern. During Teleop, the
lights do a chaser pattern when discs are being fired.
DATA OUTPUTS FROM SIDECAR:
Byte(Bin)       Byte(Dec)        Definition
00000000        0                Autonomous, not shooting
00000001        1                Autonomous, shooting
00000010        2                Teleop, not shooting
00000011        3                Teleop, shooting
ARDUINO UNO I2C CONNECTIONS:
Analog 4 on the arduino is SDA
Analog 5 on the arduino is SCL
DIGITAL SIDECAR I2C CONNECTIONS:
Google it.
Connect analog 0 to a long piece of bare wire. This helps make
the random sequences more random.
const int leds[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12}; //arrays make everything better
int i = 0;       //arbitrary integer used in the pattern generation. Probably shouldn't change this.
int d = 999;     //arbitrary integer used in debug sequence.
int w = 0;       //arbitrary integer used in debug sequence.
#define ini 30   //speed of the initialization pattern in ms. Default=30
#define ave 90   //speed of autonomous visual pattern in ms. Default=90
#define aws 125  //length of time visual effect for autonomous shooting is displayed in ms. Default=125
#define spd 15   //speed of teleop light effect in ms. Default=15
#define bfr 12   //length of teleop shooter effect buffer. Default=12
#define scm 9600 //rate of serial communication, leave this alone
void setup() {
  Serial.begin(scm);
  Serial.println("Serial: initialized");
  Serial.println("Serial: checking");
  if (Serial.available() > 0) {
    Serial.println("Serial: successfully initialized");
  for (i=0;i<13;i++) {
    pinMode(leds[i], OUTPUT);     //declare pins
  Serial.println("Digital: outputs set");
  randomSeed(analogRead(0));     //make random() randomer using elecrical noise from analog 0.
  Serial.println("Analog: inputs set");
  Serial.println("I2C: initialized");
  delay(1000);
  Wire.onReceive(incoming);
  Serial.println("I2C: ready");
  for (i=0;i<13;i++) {            //these 2 for loops are used as a debug tool
    digitalWrite(leds[i], HIGH);  //to make sure all the LEDs work and are
    delay(ini);                   //conected in the proper order.
  i = 0;
  delay(100);
    digitalWrite(leds[i], LOW);
    delay(ini);
  Serial.println("Test pattern completed");
  Serial.println("Ready");
void loop() {
  delay(100);
void incoming(int bct) {
    /* AUTONOMOUS */
//Autonomous while not shooting
    if (dat == 0) {
           if (d != 0) {
           Serial.println("Auto: not shooting");
           d = 0;
           int ran = random(0,13);
           int ranb = random(0,40);
           int ran2 = map(ranb,0,40,0,13);
           digitalWrite(leds[ran], HIGH);
           digitalWrite(leds[ran2], HIGH);
           delay(ave);                             //ooooh pretty light patterns
           digitalWrite(leds[ran], LOW);
           digitalWrite(leds[ran2], LOW);
//Autonomous while shooting
     if (dat == 1) {
           if (d != 1) {
           Serial.println("Auto: shooting");
           d = 1;
        delay(aws);
    /* TELEOP */
//Teleop while not shooting
    if (dat == 2) {
           if (d != 2) {
           Serial.println("Tele: not shooting");
           d = 2;
            digitalWrite(leds[i], LOW);          //set all lights off if we are in teleop and trigger is not pressed
//Teleop while shooting
    if (dat == 3) {
           if (d != 3) {
           Serial.println("Tele: shooting");
           d = 3;
              digitalWrite(leds[i], HIGH);         //simple for() loop that makes a 'chaser' effect
              delay(spd);                          //speed of the pattern is set by integer spd
              delay(spd);
2013
2015
